Re: info on reverse manual valve body trans! Updated [Re: BB65Barracuda] #271829
04/05/09 08:45 PM
04/05/09 08:45 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Re: info on reverse manual valve body trans! Updated [Re: WILD BILL] #271830
04/05/09 08:48 PM
04/05/09 08:48 PM
MICHIGAN
BB65Barracuda Offline OP
MICHIGAN
Ok Bill I give up.
Whats an LBA?
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
Re: info on reverse manual valve body trans! Updated [Re: BB65Barracuda] #271831
04/05/09 08:54 PM
04/05/09 08:54 PM
NJ
440challenger Offline
NJ
Low Band Apply and i believe the cheetah does not. i know mine doesn't anyway.
Re: info on reverse manual valve body trans! Updated [Re: 440challenger] #271832
04/05/09 09:54 PM
04/05/09 09:54 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
This cheetah VB has a LBA The manual VB's do not and should be in 2nd gear with wet tires for a burn out.
Re: info on reverse manual valve body trans! Updated [Re: WILD BILL] #271833
04/06/09 07:50 PM
04/06/09 07:50 PM
MICHIGAN
MICHIGAN
kinda takes the fun outta street racin!
Im probably gonna need a back up.
Re: info on reverse manual valve body trans! Updated [Re: BB65Barracuda] #271834
04/06/09 08:48 PM
04/06/09 08:48 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
I am running a full manual reverse VB as well with my stock shifter. No low band apply in first
I was tired of missing second gear at times & going straight to third with the stock shifter.
I worked with Tom Duncan of http://www.duncan-motor-sports.com/2.html to make up a reverse pattern for his Shift-R-Gate. I was his test mule
Its a slap stick style from the 1-2 shift (no button press) then the 2-3 requires a button press....no more missed 2nd gear!
from 3-2-1 it is a ratchet (no button press) with a lock before Neutral
1MYTGTX
Re: info on reverse manual valve body trans! Updated [Re: 1MYTGTX] #271835
04/06/09 08:49 PM
04/06/09 08:49 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
I bought a custom decal off a member on this site (1OFNONE)and I see Tom now sells them on his site as well
1MYTGTX
Re: info on reverse manual valve body trans! Updated [Re: 1MYTGTX] #271836
04/14/09 08:54 PM
04/14/09 08:54 PM
MICHIGAN
MICHIGAN
I think I need one of those!
Re: info on reverse manual valve body trans! Updated [Re: WILD BILL] #271837
04/14/09 11:01 PM
04/14/09 11:01 PM
MNobody Offline
MNobody  Offline
Ok i gotta ask, why no burnout's in first gear with a reverse manual VB?
Re: info on reverse manual valve body trans! Updated [Re: MNobody] #271838
04/15/09 08:12 PM
04/15/09 08:12 PM
Western NC
68Bullit Offline
68Bullit  Offline
Western NC
My thoughts too actually. Also, how would you know if you have LBA in 1st? Is that when you shift back into first on the roll, and it spins as though it's in neutral?
Re: info on reverse manual valve body trans! Updated [Re: 68Bullit] #271839
04/15/09 10:54 PM
04/15/09 10:54 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
because you stand a chance of grab, release, grab traction that will take out the sprag. That would be just like a neutral drop.
Re: info on reverse manual valve body trans! Updated [Re: 68Bullit] #271840
04/15/09 11:38 PM
04/15/09 11:38 PM
MNobody Offline
MNobody  Offline
If it free wheels in first theres no LBA
