Re: 904 Transmission ..(suite..)
[Re: HotRodDave]
#270885
03/31/09 05:33 PM
03/31/09 05:33 PM
Posts: 1,522 Ste-Sophie, Quebec, Canada
Wedgeman
Ok, so I can use the lock up converter, I take it is neutrally balanced, so I can hook it up behind my 5.9l ??
Do you know if those have 4 or 5 clutch discs ?
Also, it has a 4 spd overdrive, does it require vaccum or electric device to go in overdrive when cruising ?
Thanks...
Daniel
Re: 904 Transmission gurus.....
[Re: HotRodDave]
#270888
03/31/09 06:47 PM
03/31/09 06:47 PM
Posts: 1,488 New Mexico
74Scamp
New Mexico
Another good thing about the early 80s trans is the low gear ratio 1st and 2nd gear sets they have.
When I build a 4 clutch drum into a 5 clutch unit I just change the snap ring thickness. Usually combining 2 thin flat snaprings and useing the thick waffle clutches you can get 5 in there. I don't like the flat ones because the fuid takes longer to get out from between them, the clutches will hydro plane over each other for a second. If my pack is still tight I might slide one flat clutch in there just to get the clearance.
Another good mod is to remove the wavy snap rings and install flat rings, this reduces slipage during engagement.
If you use the trans go kit don't be afraid to drill the shift holes to the max size, it still is not a hard shift.
One more thing I like to do is run type F fluid for an even faster shift.
Mine didn't have the wavy rings, just flat rings. I just received my new bands. So, I'm just about ready to start cleaning and putting back together. Should I be looking at rebuilding or replacing the pump? Tranny came from the car in a junk yard, so don't know if anything was wrong with it.
[Re: Wedgeman]
#270890
03/31/09 07:06 PM
03/31/09 07:06 PM
Wedgeman
Thanks...
Daniel
So........any idea on that ?
[Re: HotRodDave]
#270896
03/31/09 08:29 PM
03/31/09 08:29 PM
Wedgeman
there should be at least 2 snap rings, one above the clutch pack and one below it. Sometimes they put a flat one against the wavey one so there could be 3 in one clutch pack.
The 82+ trans should have all the good stuff, 5 clutches, heavy duty steel low gear ratio planataries, and LU. When I build a trans for myself this is the one I look for. If you are going to run it behind an externally balanced 360 you can get weights from mopar to weld on the converter or you can order a converter from an aftermarket suplier that has whatever stall speed you want and has the weights on it, or you can get a BnM flex plate with the weights on it or you can order a LU 360 converter from most local parts supliers.
Whoa !.....let me get this straight ! lolll
I have to get weight to balance the converter...balance it with what ??? the crank ???? I have to take the crank out to balance it ??? i'm very confused on that.....please be very specific because I'm totally lost there Dave..
Daniel
[Re: HotRodDave]
#270897
03/31/09 08:34 PM
03/31/09 08:34 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
removing the second snap ring allows the pistons to be removed and the seals on the piston need to be changed out...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
