What Do YOU Want Howards Cams To Make For Mopars?
#267858
03/27/09 12:37 AM
03/27/09 12:37 AM
Posts: 85 Wellington, Ohio (20 minutes f...
MrMoparRacing
Howards Cams currently makes these items for Small Block Mopar: Hydraulic Flat Tappet Camshafts Mechanical Flat Tappet Camshafts Steel Billet Mechanical Roller Camshafts Billet Timing Sets Cam Correct Hydraulic Lifters Mechanical Lifters “THE ORIGINAL” Direct Lube Solid Lifters Mechanical Racing Roller Lifters (Vertical Bar) Race Valve Springs, Retainers, Locks, Seals, Caps Distributor Gears Ultimate Duty Billet Connecting Rods
Big Block Mopar: Hydraulic Flat Tappet Camshafts Mechanical Flat Tappet Camshafts (3 Bolt) Steel Billet Mechanical Roller Camshafts (3 Bolt) Billet Timing Sets (singe & three bolt) Cam Correct Hydraulic Lifters Mechanical Lifters “THE ORIGINAL” Direct Lube Solid Lifters Mechanical Racing Roller Lifters (Vertical Bar) Race Valve Springs, Retainers, Locks, Seals, Caps Distributor Gears
Howards Cams is wanting to know what MOPAR customers want Howards Cams to make that they currently do not offer. Rocker arms, crankshafts, connecting rods, pushrods, stroker pistons ect. Please be specific to exact sizes, such as rod length, stroke, piston bore, ect. Your input is highly valued!
Howards Cams products are MADE IN THE USA!
Howards Cams products are now available at Summit Racing Equipment!
Re: What Do YOU Want Howards Cams To Make For Mopars?
[Re: MrMoparRacing]
#267862
03/27/09 01:50 AM
03/27/09 01:50 AM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
An affordable quality H-beam rod and 440 6pak style flat top pistons for 440 Mopar.The rods should be stock size(.990 pin OK)6.76 length,3.75 stroke,pistons in +.020,.030.040 and .060 oversizes from 4.320 standard bore.
[Re: Chris2581]
#267863
03/27/09 02:04 AM
03/27/09 02:04 AM
Posts: 2,825 Sk. Canada
RemCharger
Sk. Canada
Same with a 383. Lots of guys still building those. Just look in the Q&A every now and then.
[Re: S/ST 3040]
#267868
03/27/09 08:03 AM
03/27/09 08:03 AM
Posts: 210 mass,usa
sickhemi
mass,usa
W2 rockers affordable
1968 gts 355 r3 six speed efi with irs in progress and 1969 convt 440 stage 6 efi 5spd dana
[Re: sickhemi]
#267870
03/27/09 08:45 AM
03/27/09 08:45 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
I'd love a 4" strock SBM USA forged/USA machined crank in the same price range as their USA forged/USA machined SBC cranks, maybe a cast crank option in the $400 range if it was cast/machined in the USA.
I'd really, really love them to make their powderforged rods in SBM size, or at least 6.125" SBC, with the little end designed such that they could have a SBM pin size option without having to do a lot of spendy rework. those powderforged rods look like they'd be awesome for a street build up, or any application where you're looking at under 600HP or so.
[Re: patrick]
#267871
03/27/09 09:25 AM
03/27/09 09:25 AM
Posts: 1,943 San Angelo, Texas, U.S.A.
1968RR
I just installed my new Howard's cam earlier this week (haven't fired yet). Y'all have great customer service and great products. Keep up the good work.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
[Re: 1968RR]
#267872
03/27/09 10:51 AM
03/27/09 10:51 AM
Posts: 1,572 wisconSIN
Blown61
wisconSIN
[Re: 1968RR]
#267873
03/27/09 11:24 AM
03/27/09 11:24 AM
Posts: 5,080 organ
maximum entropy
organ
rocker arms! offset for indy, victor, et cetera.
[Re: MrMoparRacing]
#267875
03/27/09 06:08 PM
03/27/09 06:08 PM
Posts: 3,619 Norwich CT USA
Defbob
Norwich CT USA
Big BlockForged Cranks: 4.25", 4.375, 4.5", 4.75" strokes, 2.2" x 2.009" wide rod journal on all, 2.75" mains, 8 bolt Forged Crank: 3.375" stroke, 2.375" X 2.050 wide rod journal, 2.75" mains, 8 bolt Billet Rods: 6.76" long, 2.375 journal, 1.014" width, .990 pin Billet rods: 6.86" long, 2.375 journal, 1.014" width, .990 pin
[Re: sbdemon]
#267877
03/27/09 07:08 PM
03/27/09 07:08 PM
Posts: 3,695 nc
emarine01
nc
W2/W5 rockers 1.6 1.7 ratio.
sbdemon
Post deleted by Defbob
[Re: TrWaters]
#267881
03/27/09 07:42 PM
03/27/09 07:42 PM
#267882
03/27/09 08:22 PM
03/27/09 08:22 PM
dartman366
Mt. Vernon, Ohio
lifters as good as Crane Ultra Pro Mechanical Roller Lifters
And with pushrod oiling,,ans also the w2/w5 race rocker, stand and shaft set-up in 1.6 and 1.5 ratio.
#267886
03/27/09 09:41 PM
03/27/09 09:41 PM
Defbob
Norwich CT USA
[Re: Moparteacher]
#267893
03/28/09 05:00 PM
03/28/09 05:00 PM
Posts: 576 Escondido, CA
kick_the_reverb
Escondido, CA
Drop-in Hydraulic roller lifters for small block. There are drop-in solid rollers, but as far as I know all the hydraulic rollers available require grinding on the block. thanks, Ran
"Hey mister, something's wrong with your car, it idles roughly" - number one comment I got in Israel when daily driving a 70 Barracuda with a lopey cam.
Currently working on - 1966 Dodge A100 van 318/auto Finally - disc brakes on the front. In the plans - rear disc brakes, B&M 250 blower
[Re: emarine01]
#267894
03/28/09 06:01 PM
03/28/09 06:01 PM
Posts: 251 SD USA
neonic
SD USA
sbdemon
[Re: moeflo]
#267898
03/28/09 06:59 PM
03/28/09 06:59 PM
Defbob
Norwich CT USA
How about having a hard look into what's needed for the 5.7/6.1 hemis. Valve train parts to get them into the .800+" lift range, as well as parts for the street crowd.. The aftermarket isn't saturated, their potential is off the chart and they're still in production. Help make the GM "LS" series guys miserable. It's the right thing to do.
isn't one of the limiting factors for big cams in those motors is distance of the rocker arm to the spring pocket?
[Re: Defbob]
#267899
03/28/09 07:29 PM
03/28/09 07:29 PM
FastOne
small block oil pump ( with billet gears )
[Re: FastOne]
#267900
03/28/09 08:37 PM
03/28/09 08:37 PM
Posts: 764 NW Pa.
KD800X
NW Pa.
[Re: Chris2581]
#267901
03/29/09 11:26 AM
03/29/09 11:26 AM
Posts: 74,948 U.S.S.A.
JohnRR
U.S.S.A.
Sstock length would be 6.768 , that .008 makes a difference when the piston makers decided they needed to make a little shorter CH piston that'S ALREADY .020 in the hole on a factory blueprint deck , not that everyone has a factory blueprint deck .
[Re: dartman366]
#267903
03/29/09 12:02 PM
03/29/09 12:02 PM
Posts: 416 Eagleville Tn.
rtstreet
Eagleville Tn.
LIFTERS and if this were a wish list a low deck cast iron 4.500 bore block that would go to atleast 4.580 if not 4.625
[Re: rtstreet]
#267904
03/29/09 02:58 PM
03/29/09 02:58 PM
Posts: 2,129 Vermont
TrWaters
Vermont
Did I mention anything for early hemi motors? If you are making sb parts, these early hemis are not going to require alot more tooling. And there IS a market.
TR Waters
[Re: JohnRR]
#267905
03/29/09 06:32 PM
03/29/09 06:32 PM
Posts: 607 Boise
Moparteacher
Boise
If you can make them for less than $500 I will buy them tomorrow!
It would end up being a stock replacement rod for that price , is that what you are looking for ?
There isn't really anything wrong with the eagle rod except it being for a flaoting pin which means the only piston you can use it with is KB piston
Yes! Stock replacement w/1.094 floating. The Eagles have excessive side clearance on the big end, and are too wide on the small end to fit into a KB without modifications. The small end must be narrowed to fit into a KB #162 for 383.
And, whenever possible I prefer to purchase designed in, made in, finished in, distributed in, and owned by America/American.
[Re: Moparteacher]
#267906
03/29/09 06:46 PM
03/29/09 06:46 PM
JohnRR
U.S.S.A.
well then I guess thats a good thing since the KB162 is a useless POS and should be a persons LAST RESORT when it comes to 383 piston choice .
I like to buy American products also , but americans have become accustomed to a certian standard of living so unless the majority of americans want to earn the wage of a 3rd world sweat shop worker then the 500 american rod is a pipe dream at best ...
But I digress ...
[Re: JohnRR]
#267909
03/29/09 07:57 PM
03/29/09 07:57 PM
Posts: 607 Boise
Moparteacher
Boise
The KB 162 has it's appropriate place in the market even if it's not in a high performance application. Not everybody runs all-out and heads-up.
As for the cost of American made product and the cost of the American standard of living; being accustomed to a higher standard of living is a good thing and should be rightfully defended, and we should hope others can enjoy the rewards of Liberty, Freedom, and the inalienable rights that have secured our standard of living.
I am fully aware of the sacrifices that have ensured my rights and liberties that have enabled Americans, and so many others, to take advantage of the secured opportunities that have allowed for a higher standard of living.
I also understand that seeking an unrealistic value for an American made product results in a lower standard of living, not just for those manufacturing the product, but for all Americans, with the end result being the end of American manufacturing.
If an American made con-rod under $500 is a pipe dream then so be it. I'm alright with that. I will gladly pay more to ensure my continued standard of living and that of the American employees that make the products I purchase, it just means I won't buy it tomorrow. I will need to save before the purchase but I will still insist on American made first before cost, for the VALUE that comes from helping to ensure my family, and others, a higher standard of living is greater than the savings that may be made from buying from a government that disreguards civil rights, human rights, liberty, freedom, and democracy.
I fully believe buying product from a Communist controlled country undermines all that has been sacrificed in the last 233 years! And I can give a rats [Edited by Moparts - Keep it clean] if anybody thinks otherwise!
So, if Howards makes 383 rod, in the USA, I will buy it.
[Re: Moparteacher]
#267911
03/29/09 09:25 PM
03/29/09 09:25 PM
patrick
Grand Haven, MI
a decent priced drop on spring/retainer for a magnum head that's in the 350lb/in range and a coil bind height of around .95-1", that maybe even used stock retainers?
budget spring/retainer choices are very slim for a magnum....
[Re: Moparteacher]
#267912
03/29/09 11:49 PM
03/29/09 11:49 PM
JohnRR
U.S.S.A.
The KB162 has it's place if you want to build a LOW COMPRESSION PIG, .024 in the hole AND a CANYON like valve TROUGH at 5cc ...
As far as the rod , if they make it I'll buy it also , but considering the 383/400 market I'm NOT holding my breath ...
[Re: MrMoparRacing]
#267913
03/30/09 12:20 AM
03/30/09 12:20 AM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
4.25 stroker crank for small block mopars with 2.0 chevy journals so it will easily fit any small block mopar with minimal grinding and lots of rods to pick from. You could take it a step farther and make it in a kit with good 6.125 I beam rods and pistons you could steal all of hughes thunder with their honda journal crank that only gives you 426 inches.
[Re: MrMoparRacing]
#267914
03/30/09 12:21 AM
03/30/09 12:21 AM
HotRodDave
Kalispell Mt.
An oil through flat tappet solid lifter that costs less than a hydraulic since they are easier to make.
[Re: MrMoparRacing]
#267917
04/01/09 08:05 AM
04/01/09 08:05 AM
patrick
Grand Haven, MI
"Obviously, some items are not feasible (cost vs volume) to do but we can sure get working on some of this. Thanks for all your help and efforts."
This is a direct quote from one of the Howards Cams Tech guys! So keep the ideas coming on parts that you would buy if Howards Cams made them.
nice thing with the small block stuff I mentioned, with a minor change, or a little thought into the design, they should be able to make a mopar powderforged rod from a 6.125" chevy blank, w/a little secondary machining change, same with a SBM stroker crank. the magnum spring could be applicable to other makes as well, it'd basically be a 1.65" or so IH spring w/~100-120 seat pressure, and a 1" or so coil bind height and somewhere between 300-350lb/in rate
for people requesting the rocker arms, I wonder how the powder forging technology would work in a rocker....
[Re: MrMoparRacing]
#267918
04/02/09 06:58 PM
04/02/09 06:58 PM
Posts: 5,080 organ
maximum entropy
organ
how about a rev kit for big and small block. i'd go for a solid roller on the street in a heartbeat if only a rev kit were available for a reasonable price!
