Page 2 of 4 1 2 3 4
Re: What Do YOU Want Howards Cams To Make For Mopars? [Re: MrMoparRacing] #267878
03/27/09 07:12 PM
03/27/09 07:12 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
Fordged SB cranks in 4.125, 4.250, 4.375. Rod journals of 2" would be OK.
Re: What Do YOU Want Howards Cams To Make For Mopars? [Re: Blucuda413] #267879
03/27/09 07:18 PM
03/27/09 07:18 PM
Richmond Va, KeislerTKO 60...
V
VanishPt Offline
VanishPt  Offline
V
A mechanical fuel pump for a Hemi that does not require grinding anything.
Re: What Do YOU Want Howards Cams To Make For Mopars? [Re: VanishPt] #267880
03/27/09 07:30 PM
03/27/09 07:30 PM
Vermont
TrWaters Offline
TrWaters  Offline
Vermont
Cam cores for Chrysler, Dodge, and Desoto early hemis.
TR Waters
Post deleted by Defbob [Re: TrWaters] #267881
03/27/09 07:42 PM
03/27/09 07:42 PM
Re: What Do YOU Want Howards Cams To Make For Mopars? #267882
03/27/09 08:22 PM
03/27/09 08:22 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
lifters as good as Crane Ultra Pro Mechanical Roller Lifters
And with pushrod oiling,,ans also the w2/w5 race rocker, stand and shaft set-up in 1.6 and 1.5 ratio.
Re: What Do YOU Want Howards Cams To Make For Mopars? [Re: MrMoparRacing] #267883
03/27/09 08:27 PM
03/27/09 08:27 PM
Peru
cbarracuda Offline
cbarracuda  Offline
Peru
mechanical camshaft using mushroom tappet 316 duration 107 crnterline valve lift 654 for SB and BB thanks
Re: What Do YOU Want Howards Cams To Make For Mopars? [Re: cbarracuda] #267884
03/27/09 08:42 PM
03/27/09 08:42 PM
Keysville, VA
drag440 Offline
mopar addict
drag440  Offline
mopar addict
Keysville, VA
I would like to see a cam button and bolt kit that will work on big blocks with aluminum front covers.
Re: What Do YOU Want Howards Cams To Make For Mopars? [Re: MrMoparRacing] #267885
03/27/09 08:45 PM
03/27/09 08:45 PM
Keysville, VA
drag440 Offline
mopar addict
drag440  Offline
mopar addict
Keysville, VA
I would also like to see some off the shelf, solid roller NOS cams for Mopars.
Re: What Do YOU Want Howards Cams To Make For Mopars? #267886
03/27/09 09:41 PM
03/27/09 09:41 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Re: What Do YOU Want Howards Cams To Make For Mopars? [Re: MrMoparRacing] #267887
03/27/09 11:48 PM
03/27/09 11:48 PM
Wellington, Ohio (20 minutes f...
MrMoparRacing Offline OP
Howards Cams tech guys are reading this post so please keep the ideas coming on what you would buy if they made it. Once again Howards Cams products are AMERICAN made including their crankshafts and connecting rods!
Re: What Do YOU Want Howards Cams To Make For Mopars? [Re: MrMoparRacing] #267888
03/28/09 12:03 AM
03/28/09 12:03 AM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
How about a 425"-440" SB stroker kit. Also rockers to fit w-2,w-5 & maybe indy heads.
Re: What Do YOU Want Howards Cams To Make For Mopars? [Re: DavidDean] #267889
03/28/09 04:13 PM
03/28/09 04:13 PM
Lexington South Carolina
johnnyp Offline
johnnyp  Offline
I second this...
Re: What Do YOU Want Howards Cams To Make For Mopars? [Re: DavidDean] #267890
03/28/09 04:32 PM
03/28/09 04:32 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
a good and fairly priced set of rockers with everyting that goes with them for W2-5 heads
Re: What Do YOU Want Howards Cams To Make For Mopars? [Re: MrMoparRacing] #267891
03/28/09 04:48 PM
03/28/09 04:48 PM
Boise
Moparteacher Offline
Boise
Direct lube HYDRAULIC .904" lifters compatible with high spring pressures for typical stock eliminator applications.
I-beam 383 rods. Stock sizing...<810 grams. PLEASE!
Currently the only "shelf" rod for 383's are Eagle H-beam at over 840 grams and from overseas.
Custom Cunningham, Manley etc. rods are $1400.-$2100.
If you can make them for less than $500 I will buy them tomorrow!
Re: What Do YOU Want Howards Cams To Make For Mopars? [Re: Moparteacher] #267892
03/28/09 04:59 PM
03/28/09 04:59 PM
south louisiana
lowell66dart Offline
south louisiana
W2 VALVETRAIN STUFF.....
2021 Dodge 2500 4WD Cummins
2020 Challenger R/T Scat Widebody
2007 Charger R/T 5.7
Re: What Do YOU Want Howards Cams To Make For Mopars? [Re: Moparteacher] #267893
03/28/09 05:00 PM
03/28/09 05:00 PM
Escondido, CA
kick_the_reverb Offline
Escondido, CA
Drop-in Hydraulic roller lifters for small block.
There are drop-in solid rollers, but as far as I know all the hydraulic rollers available require grinding on the block.
thanks,
Ran
"Hey mister, something's wrong with your car, it idles roughly" - number one comment I got in Israel when daily driving a 70 Barracuda with a lopey cam.
Currently working on - 1966 Dodge A100 van 318/auto
Finally - disc brakes on the front.
In the plans - rear disc brakes, B&M 250 blower
Re: What Do YOU Want Howards Cams To Make For Mopars? [Re: emarine01] #267894
03/28/09 06:01 PM
03/28/09 06:01 PM
SD USA
neonic Offline
neonic  Offline
SD USA
W2/W5 rockers 1.6 1.7 ratio.
sbdemon
Re: What Do YOU Want Howards Cams To Make For Mopars? [Re: VanishPt] #267895
03/28/09 06:26 PM
03/28/09 06:26 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
One piece Big Block oil pump cover similar to the one Ted use to make
Ted's pump cover
Re: What Do YOU Want Howards Cams To Make For Mopars? [Re: Defbob] #267896
03/28/09 06:43 PM
03/28/09 06:43 PM
nc
moeflo Offline
moeflo  Offline
nc
How about having a hard look into what's needed for the 5.7/6.1 hemis. Valve train parts to get them into the .800+" lift range, as well as parts for the street crowd.. The aftermarket isn't saturated, their potential is off the chart and they're still in production. Help make the GM "LS" series guys miserable. It's the right thing to do.
Re: What Do YOU Want Howards Cams To Make For Mopars? [Re: Defbob] #267897
03/28/09 06:46 PM
03/28/09 06:46 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Big Block Steel roller tip rocker arms. bushed, not roller bearing, with 3/8" adjusters
1.5, 1.6, & 1.7 ratios
Big Block:
.904" Solid Roller lifters with oil pressure feed to the roller bearing and/or pressure feed to the pushrod
Page 2 of 4 1 2 3 4
