Stock Radiator Flow Question #265958
03/25/09 11:21 AM
03/25/09 11:21 AM
Anonymous OP
Anonymous OP
Hi all,
Just wanted to know if anyone knows the stock radiator flow of a 26" big block radiator or if there is a way to calculate it.
I have been having a problem with overheating and was contemplating an electric waterpump (35gpm).
Right now the car will drive all day around 200F but as soon as I hit traffic it will start climbing and will drop back to around 205F.
Why I ask is so I can decide whether or not the electric waterpump will outcool the highflow waterpump I have on right now.
I have done all their is to do according to all the information I have gathered through the years on this board. (Small fans, bigger fans, different kinds of schrouds, materials etc, timing)....
It's just seems like this is the temperature the car wants to work but I'm not comfortable with it....
Any info will be greatly appreciated.
Have a great day!
Re: Stock Radiator Flow Question #265959
03/25/09 11:25 AM
03/25/09 11:25 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Don't have an any idea on how to calculate that but if its a stock radiator maybe you need to add some cores.
Re: Stock Radiator Flow Question [Re: ademon] #265960
03/25/09 11:33 AM
03/25/09 11:33 AM
Anonymous OP
Anonymous OP
Forgot to add, the rad has been recently recored with 3 cores...
Re: Stock Radiator Flow Question #265961
03/25/09 11:41 AM
03/25/09 11:41 AM
Not enough airflow and or inadequate radiator or a combination of both. If you have a 7 blade properly spaced(into the shroud) thermal clutch fan I'd upgrade the radiator. Your w/p is plenty adequate.
Re: Stock Radiator Flow Question [Re: RapidRobert] #265962
03/25/09 11:55 AM
03/25/09 11:55 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
I would say that you have plenty of coolant flow but you have an air flow problem. Make sure to have a good fan and shroud and the radiator support sealed to the hood. Anything to get better air flow through the radiator at low speeds where you are having your problems.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
