How Close is your Mopar Fan Clutch to Rad...B Body #265307
03/24/09 07:54 PM
03/24/09 07:54 PM
DC, MD Suburbs
440PURSUIT Offline OP
DC, MD Suburbs
My fan is probably 1/2" from core!
I would be concerned but I used a steel mount. Is this normal? All fittings/petcock will need to be pulled to install the rad... Just seems too close..Thoughts? Thanks
Re: How Close is your Mopar Viscous Fan to Rad...B Body [Re: 440PURSUIT] #265308
03/24/09 08:35 PM
03/24/09 08:35 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Dude be careful. I bought one for that 67 and it fit...barely. When I hit the brakes hard you could hear it go into the rad. you need a different clutch shaft.
Re: How Close is your Mopar Viscous Fan to Rad...B Body [Re: Mr.Yuck] #265309
03/24/09 10:22 PM
03/24/09 10:22 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Most instruction sets I have ever seen call for 1" clearance.
Re: How Close is your Mopar Fan Clutch to Rad...B Body [Re: 440PURSUIT] #265310
03/24/09 10:59 PM
03/24/09 10:59 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Normal with a 4 core radiator.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: How Close is your Mopar Fan Clutch to Rad...B Body [Re: HealthServices] #265311
03/24/09 11:55 PM
03/24/09 11:55 PM
Iowa
70B Body Offline
70B Body  Offline
Iowa
Sometimes you need it to miss by more than 1 inch,one of them time's is when you break 1 motor mount.And have the other mount so loose you don't need a wrench to take it off.For got to take a picture of the radiator,but can tell you it was not a pretty site. But really 1 inch is about perfect.
1970 Satellite 383/AT
Re: How Close is your Mopar Fan Clutch to Rad...B Body [Re: HealthServices] #265312
03/25/09 04:45 PM
03/25/09 04:45 PM
Avondale AZ
Prodart440 Offline
Prodart440  Offline
Avondale AZ
Mine is close enough I have to take the fan off to change the belts. I would say within 1/4 of an inch.
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
Re: How Close is your Mopar Fan Clutch to Rad...B Body [Re: Prodart440] #265313
03/25/09 05:02 PM
03/25/09 05:02 PM
So Cal
So Cal
That’s what all the marks on the radiator are from...
I eventually removed the fan to install the belts. This is after I broke the fan shroud
Re: How Close is your Mopar Fan Clutch to Rad...B Body [Re: HealthServices] #265314
03/25/09 05:20 PM
03/25/09 05:20 PM
scratchnfotraction Offline
if its running a shroud the fan blade should be sticking 3/4 of the blade in the shroud and 1/4 of the blade out of the shroud for best flow
the rad should be seal to the top of the core support to stop the air flow over the top of the rad to more direct it through the rad
I dont think it does it any good close to the rad as it can get like that,IMO
got the hood,rad,belts,upper rad hose,and not to mention the fan
side steped the clutch at 4800rpms and broke a mount.... then went and changed pants then came back and
I like a direct drive fan too,they have a few sizes for spacers and they are easy to get it in the spot you want
if you used a 1/2 spacer and bolted a direct drive fan blade close to the pully with just enuff room for belts and pully you would gain more room at the rad
and may even be able to fine tune it in a NEW shroud
I used a 7 blade soild fan from a 68 /6 Dart for yrs and worked fine...just dont drop stuff in it
unless ya goota have a clutch fan
Re: How Close is your Mopar Fan Clutch to Rad...B Body [Re: scratchnfotraction] #265315
03/25/09 08:40 PM
03/25/09 08:40 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
Mine is 1" away using the stock 2863216 440 18" fan blade with a 3462179 clutch (which is supposed to be from a 400 Max cool application)
This is with a 3 core "055" radiator
When I was running the MP Viscous package the clearance was about 1/2 - 3/4"
I have heard some use a clutch made for a Jaguar which is shorter...
1MYTGTX
Re: How Close is your Mopar Fan Clutch to Rad...B Body [Re: 1MYTGTX] #265316
03/26/09 08:34 AM
03/26/09 08:34 AM
I dont see how you can get one shorter than the one in the pic of healthservices rad and fan
thats a short clutch right there
Re: How Close is your Mopar Fan Clutch to Rad...B Body [Re: 440PURSUIT] #265317
03/26/09 08:41 AM
03/26/09 08:41 AM
Louisiana
duckblind Offline
duckblind  Offline
Louisiana
Check out my post from a few months back. My fan was scraping my radiator. As recommended in the post, I switched to the Imperial fan clutch for a 80 something jaguar and the problem was solved. Here is a link to my original post. The link includes the part number to the clutch that I purchased. https://board.moparts.org/ubbthreads/show...rue#Post4907297
Re: How Close is your Mopar Fan Clutch to Rad...B Body [Re: duckblind] #265318
03/26/09 09:52 AM
03/26/09 09:52 AM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
Mine is from 1/2 to 3/4 inch away from the radiator core. Been like that for a few years. I drive like I stole it. No problems.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: How Close is your Mopar Fan Clutch to Rad...B Body [Re: Junky] #265319
03/26/09 07:49 PM
03/26/09 07:49 PM
DC, MD Suburbs
DC, MD Suburbs
Thanks for the info....I'm off to exchange the Mopar App to the Jaguar....I'm encouraged.
1969 Hemi Charger R/T,
1970 Charger 472 Hemi 6 Sp
1969 Charger Pro Tour Project
1971 Barracuda Convert
1970 440 6pack Superbird,
1968 Fury I Police Pursuit 440 Super Commando 2 door sedan (Black/Blue)
1967 Barracuda Convert
1968 Barracuda Coupe
1972 Charger w 383
1972 Sebring Plus 440-6 Clone
1969 Coronet Pro Street
2009 Challengeer SRT8 stick
1992-1986 Body 2500 4x4 440 stick
1982 Ramcharger 318 Sniper- getting enhanced.
1997 Ram B3500 Van 5.9
1991.5 W250 Cummins- Big Chief
Re: How Close is your Mopar Fan Clutch to Rad...B Body [Re: scratchnfotraction] #265320
03/26/09 10:56 PM
03/26/09 10:56 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Check out EBay and the swap meets look for a fan clutch #FC28. Direct Mopar replacement made by TRW it is about 2 3/4" in total height.
We checked out the mentioned universal Jag one but to use this one has to drill out the water pump shaft hole in the OE pulley. Also the slotted mounting holes don't snug done as nicely as the closed OE Mopar mounting..
Just my $0.02...
Re: How Close is your Mopar Fan Clutch to Rad...B Body [Re: Sinitro] #265321
03/28/09 04:00 PM
03/28/09 04:00 PM
DC, MD Suburbs
DC, MD Suburbs
I got the Jag clutch today....Do you guys use a bushing as the hub is larger on the clutch than the Mopar water pump? C
1972 Charger w 383
Re: How Close is your Mopar Fan Clutch to Rad...B Body [Re: 440PURSUIT] #265322
03/28/09 05:36 PM
03/28/09 05:36 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
Those fan clutches come with a pilot shaft bushing. If it's missing, take it back and get one with the bushing.
