POINTS OF LEVEL FOR ROLL BAR #2625099
02/23/19 02:07 PM
02/23/19 02:07 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
What are some good level points when getting ready to install a simple roll bar? The garage floor is not very level. Got some consistent measurement from the rocker rails. Not much flat surface for L to R. I don/t trust the radiator support because this car had a R fender bender in its history. Once I get some good level points, I'll shim each tire to level.
Re: POINTS OF LEVEL FOR ROLL BAR [Re: A/MP] #2625101
02/23/19 02:22 PM
02/23/19 02:22 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
When I installed mine I just measured and made the margins the same.
Re: POINTS OF LEVEL FOR ROLL BAR [Re: A/MP] #2625102
02/23/19 02:23 PM
02/23/19 02:23 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Rear package tray area. Not always, but close.
69 GTX 68 Road Runner
Re: POINTS OF LEVEL FOR ROLL BAR [Re: A/MP] #2625110
02/23/19 02:32 PM
02/23/19 02:32 PM
Nevada
merpar Offline
merpar  Offline
Nevada
I would say jack the car up and level off the bottom of the frame rails. Factory chassis cars are about impossible to get it perfect. But the closer the gooder.
Re: POINTS OF LEVEL FOR ROLL BAR [Re: A/MP] #2625129
02/23/19 03:38 PM
02/23/19 03:38 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Suspension mounting points should be as close as anything. Locating holes in the subframes and rocker pinch welds as well. 60s, 70s and early 80's cars are all over the place. If the car has been hit or had sheetmetal replaced, good luck.
Use stands under the tires or support the car at multiple places including suspension mounting locations. Make sure the doors all open and close right.
Roll bars and cages require you to use your eyes as well as your tape measure and level. It is not uncommon to have to make something a little crooked to make it look right in the car. Work off of the center of the car to build the main hoop. If it's a pre-bent kit, you're kind of stuck making it look right as bent.
Re: POINTS OF LEVEL FOR ROLL BAR [Re: CMcAllister] #2625201
02/23/19 08:08 PM
02/23/19 08:08 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Is there a source to buy pre-bent bars that go through the package tray. I was going to keep the back seat in my car and I have a Jegs kit I got about 20 years ago but the bars are straight.
Probably just going to have to bend my own but I just thought I'd ask here.
Gus beer
64 Plymouth Savoy
Dana 60
Re: POINTS OF LEVEL FOR ROLL BAR [Re: A/MP] #2625233
02/23/19 09:40 PM
02/23/19 09:40 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
I always use the rockers front to rear.Side to side I use a piece of square tube across the front and rear frame rails. If the level points are slightly different, split the difference. Put the car on jack stands on the frame and use cheap vinyl tile under them to level it. I built some adjustable stands for under the far rear frame rails to keep the car from sagging. Works great for me. Rhodesracecars.com make nice,reasonable cage kits. They will do any modifications to the cage you want.
Re: POINTS OF LEVEL FOR ROLL BAR [Re: A/MP] #2625235
02/23/19 09:43 PM
02/23/19 09:43 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Any idea of what level (pun intended) of level you are trying to achieve, other then "looking level"? I suspect what you are thinking is you are trying to correct current chassis to a satisfactory "level" state, before locking it in, with an added roll bar, to whatever you have now, correct?
Re: POINTS OF LEVEL FOR ROLL BAR [Re: A/MP] #2625295
02/24/19 01:22 AM
02/24/19 01:22 AM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
I was "levelheaded" before I was married and had kids. Now everything seems to be askew. I'm just looking to have the car sit level before I start installing the S&W 8 pt made for my Aspen. Considering that the concrete floor is not, an addition was made to the existing garage and there are some inclines were one floor meets the existing floor. Can I just let the car sit on the concrete and just adjust the L to R of the body and just let the front to back be the way it sits on the floor? Weld it in from there?
Re: POINTS OF LEVEL FOR ROLL BAR [Re: justinp61] #2625330
02/24/19 05:09 AM
02/24/19 05:09 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
More or less what I did for my 6 point bar. I already had frame connectors in the car that I had installed as level as I could get right. Then I just basically made my bar level to the car and to the rocker panels. Since my car is basically stock body wise and not setup with a race car suspension I just leveled it to the rockers and made sure it looked level in the car. Ron
