Re: 413 valve size
[Re: als499]
#2624713
02/22/19 02:41 PM
02/22/19 02:41 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I’d expect some problems with the ex valve if you run much over .500 lift.
Not sure on the intakes.
Re: 413 valve size
[Re: als499]
#2624886
02/22/19 09:28 PM
02/22/19 09:28 PM
fast68plymouth
So. Burlington, Vt.
1.81’s touch the bores on a std bore 383 at about .550 lift...... and since the 413’s bore is .125” smaller...... I think it’ll touch with less lift.
