Page 2 of 5 1 2 3 4 5
Re: Pinto Duster steering part 2 [Re: DemonDust] #262505
03/23/09 07:43 PM
03/23/09 07:43 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
What is the difference between the A-body steering arms and B-body steering arms?
Do you have the B-body arms, Your steering arms look different from my 73 A-body arms.
In addition to what others have said you also want the tie rod total length pivot points to be the same length as the lower control arm pivot points. Witch is about 13.5 or so. I dont know the exact measurement of the A-body but its about that.. mike
Re: Pinto Duster steering part 2 [Re: DemonDust] #262506
03/24/09 09:24 PM
03/24/09 09:24 PM
Raleigh, NC
rockerbob Offline
rockerbob  Offline
Raleigh, NC
Am I looking at something wrong or is your car a front steer. I thought all a.b.c& e bodies where rear steer?
2005 Dakota 4X4 3.7 2004 Rumble Bee 5.7 1978 Diplomat 318 1969 Satellite 318 "bracket racer" 1966 Barracuda (in progress ) 1964 Dodge 330 (future race project) 1962 Belvedere (HUM????)
Re: Pinto Duster steering part 2 [Re: rockerbob] #262507
03/24/09 09:41 PM
03/24/09 09:41 PM
Northeast, Arkansas
Dodgeman67 Offline
Dodgeman67  Offline
Northeast, Arkansas
They are till you swap sides with the steering arms and mount a rack and pinion up front.
Post deleted by Defbob [Re: Dodgeman67] #262508
03/24/09 10:16 PM
03/24/09 10:16 PM
Re: Pinto Duster steering part 2 #262509
03/25/09 12:59 AM
03/25/09 12:59 AM
Menomonee Falls
DemonDust Offline OP
Menomonee Falls
Well I decided to take everything out but the back two corners of the K frame that hold the torsion bars and control arms. They are boxed in but need some TLC for cosmetics
Made the new K frame today. I'm thinking of running the torque bars like yours Fred, with the heims on both ends or put the stock ones back in cut and rethread and see where they can mount with a heim.
I took some pics. I tried to get one to show the relation of the LCA pivot point to the new frame.
I looked at your pics Fred. I can't tell from the pics if the rack is straight across(not in front of the steering arms) I can see the tie rods are pretty much level.
You inner tie rod must be a little lower than LCA pivot point? If you look in the pic I took you can see the LCA pivot point is about 2" below the frame rail. The square tube is 2x3.
I see some color bands on your steering arms, where they bent out toward the tire?
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Post deleted by Defbob [Re: DemonDust] #262510
03/25/09 01:12 AM
03/25/09 01:12 AM
Re: Pinto Duster steering part 2 #262511
03/25/09 01:29 AM
03/25/09 01:29 AM
Menomonee Falls
Menomonee Falls
I just want to make sure we're on the same page.
I know looking from the front of the car the tie rods are straight across. Looking from the engine compartment down is where I'm wondering if it's straight across.
Thanks for your time Fred it's greatly appreciated.
SDG Motorsports
Re: Pinto Duster steering part 2 [Re: DemonDust] #262512
03/25/09 06:05 AM
03/25/09 06:05 AM
Raleigh, NC
rockerbob Offline
rockerbob  Offline
Raleigh, NC
Thanks guys. I'm learning a lot. This is good stuff!
Re: Pinto Duster steering part 2 [Re: Dodgeman67] #262513
03/25/09 10:56 AM
03/25/09 10:56 AM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
Dodgeman did you make those frame rails or did you some like S&W???
Re: Pinto Duster steering part 2 [Re: DemonDust] #262514
03/25/09 03:02 PM
03/25/09 03:02 PM
Menomonee Falls
Menomonee Falls
Fred, can you also get a pic looking down on your steering arms.
Also from A body to B body steering arms is one longer? Also does one curve upward and curve downward?
I can get disc brakes off of a 75 volare from the junk yard for $80. Is this a good deal? This includes rotors, calipers, spindles. Not sure if the upperarms will exchange?
SDG Motorsports
Re: Pinto Duster steering part 2 [Re: DemonDust] #262515
03/25/09 03:06 PM
03/25/09 03:06 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Years ago I used F/M body spindles on a A-body and
I recall that I had to increase the size of the upper
bal joint taper to fit the A-body ball joint
Re: Pinto Duster steering part 2 [Re: DemonDust] #262516
03/25/09 06:18 PM
03/25/09 06:18 PM
Menomonee Falls
Menomonee Falls
The K frame is done.
I have the rack mocked up in place, it's a tight fit. There are a few problems.
The inner tie rods are almost maxed out to be inline with the steering arms. I can raise the engine up about .750 lower the rack .500 and I'd be below the oil pan then and be able to move the rack back 4.000, that will bring the tie rods more straight across. If I do that the LCA pivot will be about 4.500 above the inner tie rods. I'll have to bring the ride up a bit to make the tie rods level horizontally.
Here's some pics. Please feel free to let me know what you think.
SDG Motorsports
Re: Pinto Duster steering part 2 [Re: DemonDust] #262517
03/25/09 06:56 PM
03/25/09 06:56 PM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
You won't be able to turn very sharp. The rack is so far foward the tie rod and lowerball joint will go past center when you turn sharp and you'll have to get out and kick the tire back straight.
One day I will have something cool here.
Re: Pinto Duster steering part 2 [Re: sdaurity] #262518
03/25/09 07:00 PM
03/25/09 07:00 PM
Menomonee Falls
Menomonee Falls
Yeah I know, thats why I'm asking how many more problems I will create by moving the rack back.
So close, yet so far away
SDG Motorsports
Re: Pinto Duster steering part 2 [Re: DemonDust] #262519
03/25/09 07:01 PM
03/25/09 07:01 PM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
Give me a few min. I'll put up some pics of mine.
Re: Pinto Duster steering part 2 [Re: sdaurity] #262520
03/25/09 07:12 PM
03/25/09 07:12 PM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
Here are some of mine
Re: Pinto Duster steering part 2 [Re: DemonDust] #262521
03/25/09 07:13 PM
03/25/09 07:13 PM
Raleigh, NC
rockerbob Offline
rockerbob  Offline
Raleigh, NC
Would it be possible to extend the steering arms out 2 inches or so to meet the rack?
Re: Pinto Duster steering part 2 [Re: rockerbob] #262522
03/25/09 07:17 PM
03/25/09 07:17 PM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
Its cast, I wouldn't want to go down the track with something welded to it like that but?
Re: Pinto Duster steering part 2 [Re: DemonDust] #262523
03/25/09 07:19 PM
03/25/09 07:19 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Your Rack is going to have to move back to take your almost maxed out inner tierod angle away. Look at your pic #4 When you turn your steering sharp left, look at the direction the outer steering arm takes.
It will swing to the rear of the car and if the rack arm is maxed out it will bend itself.
I admire what your doing but you need to put down the welder and do some more study. I dont have this rack thing down 100% myself.
Dont be like me and end up having to reposition your Rack 4 times. www.heidts.com and www.lonacreracing.com has some good info on positionening a rack.
With the A bodys you cant really get the rack exactly were it needs to be. So at best its a comprimise IMO The rack needs to be further Up and Back then you have it. But you see the problems with that no doubt. mike
Re: Pinto Duster steering part 2 [Re: DemonDust] #262524
03/25/09 07:22 PM
03/25/09 07:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Lengthen the steering arms 2", it wont hurt a thing
and it actually helps, you dont want a fast reacting
steering on the dragstrip. I had to lengthen mine on
my last chassis
