Water spots in cylinders #262464
03/22/09 10:01 PM
03/22/09 10:01 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Pulled a boo boo a couple years ago and left some water spots on 3 of my cylinders. Pulled the heads off and completetly forgot about some water that came out of the head when I took it off. I saw it the next day and it had left water spots in the cylinders where the rings were at the time. You cant feel the spots at all (no pitting), only see them. I highly doubt that rehoning will remove them. Will they cause any problems?
Also, the rings in 2 of the 3 cylinders have very light rust, nothing major, one swipe of steel wool will take it off.
The motor only has 45 mins of run time, so Id like to reuse everything, if possible.
Clean the rings and go or rehone and rering?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Water spots in cylinders [Re: Von] #262465
03/22/09 11:49 PM
03/22/09 11:49 PM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
Run it, it will be fine.
8.30's @3400 lbs
Re: Water spots in cylinders [Re: Mike Swann] #262466
03/23/09 12:04 AM
03/23/09 12:04 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
This bad?? I found this about 40 passes after a freshen. Never had a head gasket issue prio to this. Everything checked out ok (head and block) so I put new gaskets in and still got water in #3. Ceramic seal "cured" it. Still runs the number. FYI this engine is pretty much at the "n'th" of being used up, and is really a bunch of old school junk so we really didn't have much to lose.
Re: Water spots in cylinders [Re: J_BODY] #262467
03/23/09 01:57 AM
03/23/09 01:57 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
ceremic seal...that stuff worrys me.
after I broke in my big block, went to change the oil and it was like a milk shake.
pressurized radiator, and it held pressure fine--15psi overnight.
ran some ceremic seal, and all was well.
then it decided to NOT seal anymore after 200 street miles.
filled a cylinder with water, hydro locked it, bent a pushrod, tossed a lifter, lost oil pressure...
lucky all the bottom end parts survived and now have 3,000 miles on them. all it needed was a sleeve in 1 hole, new bearings/rings, and a new pushrod.
**Photobucket sucks**
Re: Water spots in cylinders [Re: J_BODY] #262468
03/23/09 11:23 AM
03/23/09 11:23 AM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
No, they arent that bad.
Guess you answered my question, I'll put it back together and let it eat!!
