What brand Ring & Pinion are you running in your 8.75 rear? #2624626
02/22/19 11:49 AM
02/22/19 11:49 AM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
What brand/ratio ring and pinion are you running in your 8.75 rear axle?
This 340 (10:1 compression) A-Body Mopar will most likely see a majority of time on the street and some strip. Case is a 489.
Re: What brand Ring & Pinion are you running in your 8.75 rear? [Re: vinnyd76] #2624668
02/22/19 01:23 PM
02/22/19 01:23 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
I have run 3:23 and 3:72?and 4:10. 4:10 is a bit much, but the best gear for me. 3:72 or 3:91 for street car leaning towards 3:7, I run yukon gear 4:10’s IIRC. but there is only a couple of manufacturers.
best of 11.39 at 117 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: What brand Ring & Pinion are you running in your 8.75 rear? [Re: vinnyd76] #2624678
02/22/19 01:50 PM
02/22/19 01:50 PM
E
earlymopar Offline
earlymopar  Offline
E
This one from Dr. Diff: https://www.doctordiff.com/8-3-4-ring-and-pinion.html
Mine is a 3.91 ratio. I'm running a 31" tall tire and a TKO-600 (5-speed).
- EM
