Re: Some questions about torque converters
[Re: Chargerfan68]
#2624550
02/22/19 01:51 AM
02/22/19 01:51 AM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
So, i could do that... just put it in and run it till the summer and see how it feels. Then, if no good, i can have it reworked. I guess, does that mean if i call a converter shop, they will accept and adjust a converter that was not one of theirs? Or they don’t like to touch someone else’s coverter they didn’t build?
Also, from what i gather here, if a high quality converter maker designs an optimal converter for my package, it would perform optimal at the track as well as being as efficient as possible for street driving? Im not sure how they both come into play together.
[Re: Chargerfan68]
#2624634
02/22/19 12:08 PM
02/22/19 12:08 PM
Posts: 11,991 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Ultimate tightened up my PTC converter. No problem. And was much cheaper than a new one.
The goals of a race converter would be different than those of a street converter. So there will be differences. That doesn't mean that a converter can't be dual purpose, it's just that they will have different characteristics.
Asking about street vs strip converters is like asking what's a street car.
Master, again and still
[Re: Chargerfan68]
#2624656
02/22/19 12:51 PM
02/22/19 12:51 PM
Posts: 14,491 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
The converter for a street/strip car is like essentially every other part on a street/strip car. It’s a compromise........ like the cam, carb, rear gear, etc. Most of the time the decisions for those parts are based on balancing the cars performance with the drivability on the street, along with reliability and how much street use vs track use.
It often works out that chasing a tenth or two on your street/strip car can cost you a disproportionate amount of lost street friendliness.
As I said previously, and reiterated by Dave........ you basically want as tight of a 9.5” or 10” unit as can be had, and it will still have over 3500 flash(probably closer to 4000).
“If it were me”, I’d send the one you have to Lenny at Ultimate, have him cut it open...... and then have a talk about what can be done with it.
If it’s not up to the task of 600+ ft/lbs, and it fails......... that’s more problems than just needing a different converter. It’s a trans full of metal.
[Re: Chargerfan68]
#2624698
02/22/19 02:29 PM
02/22/19 02:29 PM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
Thanks for all the good info and advice so far. The only other info that i can think of is weight is 4240 lbs with driver. Rear gears will be 3.23 for street/highway trips, and 3.91 for track. 8-3/4 rear. I will be running drag radials 28 “ tall. Only actual numbers i have are dyno numbers. They are as follows:
Rpm. Tq. Hp 3900. 609.7. 452.7 4000. 608.3. 463.3 4100. 610.6. 476.7 4200. 613.1. 490.3 4300. 621.1. 508.5 4400. 625.5. 524.1 4500. * 629.6. 539.5 4600. 628.6. 550.6 4700. 625.4. 559.7 4800. 622.0. 568.4 4900. 619.1. 577.6 5000. 616.3. 586.8 5100. 611.7. 594.0 5200. 605.8. 599.8 5300. 599.4. 604.9 5400. 592.6. 609.3 5500. 581.4. 608.8 5600. 571.2. 609.0 5700. 561.3. 609.2. * 5800. 550.7. 608.2 5900. 540.3. 607.0 6000. 531.3. 607.0 6100. 515.7. 600.6
Avg. 602.07. 559.43
So, peak torque is at 4500 rpm. Does that chang anything? I guess for strictly racing, i woukd want a 4500 stall, but for combo driving, what woukd you guys be looking for? Aside from calling and having one built, or my 10” adjusted. I will do that, but trying to understand the fundamentals and theory of it. If i can think of any other info, ill add it
4240 lbs, 68 Charger in your signature ?? how did it get so heavy, mine has d60,a518 overdrive, A/C, everything there, glass hood,4050 with me. Get your converter looked at, I had to get a custom TIGHT 10" converter built for my 512 street car, will flash 4k, but drives good on the street 3.54 gear.
[Re: Chargerfan68]
#2624743
02/22/19 03:50 PM
02/22/19 03:50 PM
Chargerfan68
New York, USA
Ok, i understand. Makes sense. Thanks
[Re: Chargerfan68]
#2624747
02/22/19 03:54 PM
02/22/19 03:54 PM
Chargerfan68
New York, USA
The car this is going in, is my 73 charger. It also has 71 grill with hideaway headlights, so that doesnt help either. Last time at the track on the scales with a completely stock 440, it was 4360 with me in it. So, im guessing at the weight with this motor and all aluminum parts swapoed onto it including headers for the ex manifolds. I figure around 4250 or so
[Re: Chargerfan68]
#2625332
02/24/19 05:28 AM
02/24/19 05:28 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
I run a Luppo Dynamic 9.5 converter in my 63 and they call it a street/strip converter and it was made to flash about 4200 behind my old 440. I now use it behind my 493 and it will still flash from about 4200 to about 4500. And I love it as the car drives around on the street like a normal stock type converter as I don't feel any slippage in it driving it normal. And it works fine at the track. I don't set the world on fire but it has given me a 1.50 sixty ft in my 63 at close to 3800 lbs and on just SS springs. You should be fine and as said as long as you have a good cooler it should work and drive fine. My converter has been in my car since 2006 with many street miles and some drag racing and it still drives great and works fine at the track. Good luck with it. Ron
[Re: 383man]
#2625748
02/25/19 03:14 AM
02/25/19 03:14 AM
Chargerfan68
New York, USA
T I run a Luppo Dynamic 9.5converter in my 63 and they call it a street/strip converter and it was made to flash about 4200 behind my old 440. I now use it behind my 493 and it will still flash from about 4200 to about 4500. And I love it as the car drives around on the street like a normal stock type converter as I don't feel any slippage in it driving it normal. And it works fine at the track. I don't set the world on fire but it has given me a 1.50 sixty ft in my 63 at close to 3800 lbs and on just SS springs. You should be fine and as said as long as you have a good cooler it should work and drive fine. My converter has been in my car since 2006 with many street miles and some drag racing and it still drives great and works fine at the track. Good luck with it. Ron Thanks Ron. I’ve always loved your ‘63. Great running street strip ride. Im gonna try to call Freddy Brown and find out what converter he used and if he has the specifics on it. Then, i can send it out for adjustment if i need to.
[Re: Chargerfan68]
#2626955
02/28/19 01:03 AM
02/28/19 01:03 AM
383man
Balt. Md
T I run a Luppo Dynamic 9.5converter in my 63 and they call it a street/strip converter and it was made to flash about 4200 behind my old 440. I now use it behind my 493 and it will still flash from about 4200 to about 4500. And I love it as the car drives around on the street like a normal stock type converter as I don't feel any slippage in it driving it normal. And it works fine at the track. I don't set the world on fire but it has given me a 1.50 sixty ft in my 63 at close to 3800 lbs and on just SS springs. You should be fine and as said as long as you have a good cooler it should work and drive fine. My converter has been in my car since 2006 with many street miles and some drag racing and it still drives great and works fine at the track. Good luck with it. Ron Thanks Ron. I’ve always loved your ‘63. Great running street strip ride. Im gonna try to call Freddy Brown and find out what converter he used and if he has the specifics on it. Then, i can send it out for adjustment if i need to. Thanks for the kind words as I also love that 68 Charger of yours that runs so good ! I would think any good converter company today should be able to build one that works good in your car on the street and the track. Ron
[Re: Chargerfan68]
#2627113
02/28/19 03:05 PM
02/28/19 03:05 PM
Chargerfan68
New York, USA
Thanks Mark. Ill be sure to give them all the info i can.
[Re: Chargerfan68]
#2627118
02/28/19 03:09 PM
02/28/19 03:09 PM
Chargerfan68
New York, USA
Can anyone go into some detail, in laymans terms (haha), what they actually do to a quality built unit, compared to a unit that is not as efficient at the track. Also same question for a street speced converter. And finally, the diff internally between a converter more geared to the track than the street. What is changed internally to change the characteristics. I know the general parts inside and terms. Thanks
