Re: button mounting
[Re: DusterKid]
#2622921
02/18/19 02:52 PM
02/18/19 02:52 PM
Posts: 34,865 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Mine is mounted on my dash, got tired of fighting the wire plus for me , it works much better there
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: button mounting
[Re: DusterKid]
#2622964
02/18/19 04:31 PM
02/18/19 04:31 PM
Posts: 11,479 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I had transbrake and line loc on the wheel. Long coil cords with quick connects at the base of the column. Rack & pinion so the steering wheel didn't have to spin 6 turns. Cords had some slack in them and worked fine. Had to watch you didn't get your feet in them getting in the car, but there was no issue once you were in.
Re: button mounting
[Re: DusterKid]
#2622968
02/18/19 04:46 PM
02/18/19 04:46 PM
Posts: 19,355 Las Vegas
Al_Alguire
Las Vegas
On the steering wheel for me always. Zip tie or secure a part of the cable close to switch to the steering wheel and if need be on the dash end as well. The cord will stretch quite a but securing the button end to the wheel will keep the stress off of it. We have three buttons on the dragster wheel as well and those wheels get turned a fair amount driving to and from the lanes and off track. The dragsters cords are secured on both ends my car is only on the wheel, with two cords, one for brake one for the chutes. Been doing it this way for years with zero issue doing it this way
Re: button mounting
[Re: DusterKid]
#2622992
02/18/19 05:37 PM
02/18/19 05:37 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
Yes it is a good idea to zip tie cord at the wheel as the weight and movement of the cord will break the wires off the switch.
