Re: preoiling issue
[Re: dIc dOc Deity !]
#2621105
02/14/19 02:34 AM
02/14/19 02:34 AM
Posts: 954 garnett kansas
rhad
garnett kansas
did you rotate the engine by hand as you were pre oiling?
my ladder of success is missing some rungs
Re: preoiling issue
[Re: rhad]
#2621107
02/14/19 02:37 AM
02/14/19 02:37 AM
RapidRobert
No I wasn't turning the crank cuz I didn't think it was needed & I didn't wanna wipe the lobes. EDIT I could turn it if that is what I am missing then regoop the lobes. MORE EDIT Doc what special tool do you have? & Doc I am gonna put that motorhome 440 in the truck with the granny 4 sp/hyd clutch.
Re: preoiling issue
[Re: RapidRobert]
#2621181
02/14/19 10:59 AM
02/14/19 10:59 AM
Posts: 601 Mass
charge70
Mass
Try loosening the rocker shafts and try to pre-oil again.You should see oil coming out of the push rods if all is well
1970 Dodge Charger R/T S.E.
1969 Dodge Dart GTS 440 M-Code
1970 Dodge Charger 500 383/4-speed w/A.C.
Re: preoiling issue
[Re: RapidRobert]
#2621217
02/14/19 12:26 PM
02/14/19 12:26 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Since RR doesn;t say...
If it's an LA engine, you need to rotate it as you prelube.
IF is't a magnum engine rotating does nothing for you.
Since you allude to oiling thru the push rods, or at least expecting to see oil out of the push rods I assume it's a magnum? If so, don't bother rotating it as that is not relevant.
Re: preoiling issue
[Re: dogdays]
#2621754
02/15/19 05:18 PM
02/15/19 05:18 PM
RapidRobert
Hey Dog its been awhile. Here is where I am at: the lifter set that has maybe 10 minutes of run time on a prior eng & on the shelf HAS the plates with metered oil (I would love to toss these in if you guys think they are still OK on the bottom convex). the set in the eng now that precipitated this thread have metering plates with NO oil holes (they had no flow). I just now stopped by O'reillys on the way home & bought a single lifter (melling & I told the man 1975 dart with a 360) & I opened it up & its flat plate has NO holes (just like the ones in the eng now). PLEASE tell me I can use the 10 min run time set OR a brand/part # of some that are metered. EDIT I ain't tossed anything (yet).
Re: preoiling issue
[Re: RapidRobert]
#2621763
02/15/19 05:48 PM
02/15/19 05:48 PM
Posts: 17,801 S.E. Michigan
ZIPPY
S.E. Michigan
You need lifters for an AMC.
Ask the local parts store for lifters for a 1974 AMC Javelin with a 360.
Rich H.
Esse Quam Videri
