98 Ram 5.9 no oil press UPDATE #2620675
02/13/19 06:41 AM
02/13/19 06:41 AM
Missouri
StrokerPost Offline OP
Missouri
The other day, when it got way below zero here, when I started up my 98 Ram I noticed after several seconds that the oil press gauge was still on zero. I tapped on the cluster cover thinking possibly from the cold it might be stuck, it wasn't. I quickly shut it off and got out to look at the oil on the dipstick. It was right on the full mark, as if it had not been running. Im certain that shouldn't be the case, but I decided to start it (yeah I know) and check it while running and it was exactly the same, so I shut it off knowing its not pumping oil. The strange part, to me anyway, is that the motor sounded completely normal, no ticking, knocking or rattling from anywhere. Any other motor ive heard with no oil press it was immediately obvious. shruggy
Given its very close to 300K miles, im sure the pump end of the intermediate shaft it worn, possibly to the point where it rounded off that morning with the thick oil from the cold, or it just broke off. QUESTION: Does that sound feasible, and how would I verify that that's what has happened? The only ways I can think of is either pull the pan and drop the pump, or pull the distributor and try to fish out the shaft. Either one is a pain in the backside. If you have any input, suggestions or experiences with this Id REALLY like to hear from you. I need this truck back up soon!
Thanks,
Ken
Re: 98 Ram 5.9 no oil press [Re: StrokerPost] #2620679
02/13/19 07:21 AM
02/13/19 07:21 AM
Guitar Jones Offline
Put a mechanical gauge on it before you do anything. Pump drives breaking or wearing out is something I've rarely seen unless debris locked up the pump.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: 98 Ram 5.9 no oil press [Re: StrokerPost] #2620684
02/13/19 08:12 AM
02/13/19 08:12 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Was on snomobile trip back in Northern Wi. back in 1996 during an all time cold snap, and my 360 tbi ramcharger started at -50F, then showed no oil pressure on gauge or light for 4 or 5 minutes. I recall still, thinking shaft had broke, whatever, but it survived and I can guess that the oil just could not get to certain places at those extremes. You might be okay.
Re: 98 Ram 5.9 no oil press [Re: StrokerPost] #2620697
02/13/19 10:09 AM
02/13/19 10:09 AM
Illinois
SIX225 Offline
SIX225  Offline
Illinois
Had a 5.2L Durango that randomly showed no oil pressure. No lifter tick, etc. Changed the oil, and months later realized I never had the problem again. Bad filter.
Re: 98 Ram 5.9 no oil press [Re: Guitar Jones] #2620704
02/13/19 10:36 AM
02/13/19 10:36 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
iagree
Until you put a mechanical gauge on it you really don't know what the oil pressure is.
Re: 98 Ram 5.9 no oil press [Re: StrokerPost] #2620711
02/13/19 11:11 AM
02/13/19 11:11 AM
tboomer Online work
tboomer  Online Work
Ken...My 95 Ram 1500 did the same thing years ago. It was the sending unit down by the filter. I would put a mechanical gauge on it as suggested to make sure. wrench
Re: 98 Ram 5.9 no oil press [Re: tboomer] #2620887
02/13/19 06:17 PM
02/13/19 06:17 PM
Missouri
Missouri
Okay, I spent quite a while just getting the old sending unit out, and was getting ready to screw in the fitting for the mechanical gauge and dropped it but it never hit the ground. My luck has not changed. So I was just about to go get another one from the store and thought I would just disconnect the coil and have my son turn the engine over while I watched the whole, which I did, and within probably 3 seconds there was oil coming up out of the hole so I am hopeful, but not convinced that it's just the sending unit but I am going to screw the mechanical gauge in and check it anyway before I buy the new sending unit. Just thought I would drop an update. Thanks for all the replies, even you Ted. LOL
Will update further when I know for sure what I have here.
Re: 98 Ram 5.9 no oil press [Re: StrokerPost] #2620917
02/13/19 07:51 PM
02/13/19 07:51 PM
Missouri
Missouri
It was indeed the sending unit that was bad, heres what the mechanical gauge shows at idle. Now just gotta button everything up. Thanks for your input guys, I appreciate it!! thumbs
Ken
Re: 98 Ram 5.9 no oil press [Re: StrokerPost] #2621416
02/14/19 08:52 PM
02/14/19 08:52 PM
Missouri
Missouri
Got the new sending unit installed in a T fitting along with a mechanical gauge and all is well. About 55 psi cruising warmed up and 25 psi at idle.
Wish I'd had a mechanical gauge all along. Anyway, thanks again guys. thumbs
Re: 98 Ram 5.9 no oil press [Re: StrokerPost] #2621604
02/15/19 11:47 AM
02/15/19 11:47 AM
tboomer Online work
tboomer  Online Work
We are all glad to help you Ken! laugh2 wave
