Re: Eagle Head
[Re: ric3xrt]
#2600375
01/02/19 12:23 PM
01/02/19 12:23 PM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
Ray if you get the chance this year try a 2.125 X 7MM intake valve....I think you'll like the results...I'm going to try a putting a vein in the next set of Eagles I do.
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
Re: Eagle Head
[Re: ric3xrt]
#2600794
01/03/19 03:17 AM
01/03/19 03:17 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Ray if you get the chance this year try a 2.125 X 7MM intake valve....I think you'll like the results...I'm going to try a putting a vein in the next set of Eagles I do. If I was going to go thru that trouble I would just buy Thitek heads. The equality of the head is just so good
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
Re: Eagle Head
[Re: mcmopar1]
#2600992
01/03/19 03:57 PM
01/03/19 03:57 PM
ric3xrt
Trumbauersville PA
How pricey are those heads, look very impressive! ThiTex ? base price is about $2500
Re: Eagle Head
[Re: sixpackgut]
#2600994
01/03/19 04:04 PM
01/03/19 04:04 PM
ric3xrt
Trumbauersville PA
Ray if you get the chance this year try a 2.125 X 7MM intake valve....I think you'll like the results...I'm going to try a putting a vein in the next set of Eagles I do. If I was going to go thru that trouble I would just buy Thitek heads. The equality of the head is just so good No doubt Thitex's are cream of the crop, but most entry level G3 hemi people aren't going to spend that kind of coin, I started this thread to get some Information out there.
Re: Eagle Head
[Re: ric3xrt]
#2601328
01/04/19 03:04 AM
01/04/19 03:04 AM
Posts: 80 Australia
aus370
Australia
Ray if you get the chance this year try a 2.125 X 7MM intake valve....I think you'll like the results...I'm going to try a putting a vein in the next set of Eagles I do. If I was going to go thru that trouble I would just buy Thitek heads. The equality of the head is just so good No doubt Thitex's are cream of the crop, but most entry level G3 hemi people aren't going to spend that kind of coin, I started this thread to get some Information out there. I love all the in depth information on this forum . I'm gonna have a go at porting my Apache heads ... i'll probably loose 30 hp ! .
Re: Eagle Head
[Re: ric3xrt]
#2603043
01/07/19 06:28 PM
01/07/19 06:28 PM
Posts: 577 Arkansas
Adrielp
Arkansas
So, rolling the short side radius angle towards the intake side of the head has proved to be one of the most effective strategies? Allows the air to start turning around the short side radius earlier correct?
Anybody try welding some taller spring seats in to raise the port roof?
Adriel Paradise Substation Design Engineer III
Re: Eagle Head
[Re: ric3xrt]
#2603326
01/08/19 10:23 AM
01/08/19 10:23 AM
ric3xrt
Trumbauersville PA
It's a V*A*N*E
Blood doesn't flow through it. It does, through a vein.
R. LL"1 teka ttha up with car tcerrect time next mez nead to speel eht word vien
Re: Eagle Head
[Re: Adrielp]
#2603328
01/08/19 10:26 AM
01/08/19 10:26 AM
ric3xrt
Trumbauersville PA
Anybody try welding some taller spring seats in to raise the port roof? not sure that putting in that type of work is worth it with the eagle head.
Re: Eagle Head
[Re: ric3xrt]
#2603537
01/08/19 06:37 PM
01/08/19 06:37 PM
Posts: 577 Arkansas
Adrielp
Arkansas
Anybody have any cutaways of the BGE cylinder heads? I'm curious of the thin areas that this cylinder may have compared to the eagle cylinder head.
Re: Eagle Head
[Re: sixpackgut]
#2617572
02/06/19 12:00 AM
02/06/19 12:00 AM
Posts: 146 Australia
L4staero
Australia
I have not spent time comparing a sharp vein to one that is wider like in the photo but it seems to get the same results.
There is another thing on the eagles that helps. Machine cut on chamber on intake valve side. None of the Apache heads Ive seen has it Ray can you elaborate on this cut a little?
Re: Eagle Head
[Re: L4staero]
#2620167
02/12/19 08:07 AM
02/12/19 08:07 AM
ric3xrt
Trumbauersville PA
There is another thing on the eagles that helps. Machine cut on chamber on intake valve side. None of the Apache heads Ive seen has it Ray can you elaborate on this cut a little? He's referring to the factory relief cut in the chamber
Re: Eagle Head
[Re: Adrielp]
#2620170
02/12/19 08:15 AM
02/12/19 08:15 AM
ric3xrt
Trumbauersville PA
Anybody have any cutaways of the BGE cylinder heads? I'm curious of the thin areas that this cylinder may have compared to the eagle cylinder head. I haven't forgot to get to this, just haven't had the time to cut up a head, the last one I did cut open was Hellcat head(same ports as the BGE)I sent off to a friend.
