727 pump modification #2619972
02/11/19 08:15 PM
02/11/19 08:15 PM
Minnesota
TrackPack Offline OP
Minnesota
Looking at converters for a 727 torqueFlite. Some say front pump modification required. What's this modification about?
Re: 727 pump modification [Re: TrackPack] #2619980
02/11/19 08:36 PM
02/11/19 08:36 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Here's a pic of the common pump mod, amounts to machining the area around the seal. The sloping cut is done at an angle of 25°.
Re: 727 pump modification [Re: TrackPack] #2620028
02/11/19 10:46 PM
02/11/19 10:46 PM
the problems your bringing up is on mainly 8 inch race converts, maybe it is on some 9 inch also confused
As John has posted you may need to do some grinding or machining on the pump housing to clear the converter sawzall
Re: 727 pump modification [Re: TrackPack] #2620095
02/12/19 12:57 AM
02/12/19 12:57 AM
Minnesota
Minnesota
I see, clearance for the smaller diameter converters. Thanks guys.
