MAGNUM FORCE WHAT THE ????
#2619960
02/11/19 07:47 PM
02/11/19 07:47 PM
Posts: 4,673 On the parachute mount
n20mstr
Called on Nov 19th, ordered drop spindles and upper control arms. Paid in full.
As of today, NO product delivered, NO email answered, NO phone call returned.
Get an answering machine ??
About to just get the money back from my bank and buy the stuff from someone else
....BAD A$$ STREET CAR.....
Re: MAGNUM FORCE WHAT THE ????
[Re: n20mstr]
#2619966
02/11/19 07:57 PM
02/11/19 07:57 PM
Posts: 22,696 Bitopia
jcc
Bitopia
"MAGNUM FORCE WHAT THE ????" The State of Magnum Force is Strong.
[Re: geo.]
#2620030
02/11/19 10:47 PM
02/11/19 10:47 PM
n20mstr
Staff too busy being on tv?
You're doing the right thing, they can't expect you to wait forever.
I'm sure someone will suggest a better source. The double adj upper arms, I don't see anyone else making them ? Guess its stock stuff for another season lol
[Re: n20mstr]
#2620038
02/11/19 10:59 PM
02/11/19 10:59 PM
Posts: 2,826 NY usa
540challenger
NY usa
I'm sure someone will suggest a better source. The double adj upper arms, I don't see anyone else making them ? Guess its stock stuff for another season lol Hotchkis has some nice ones but expensive, and I think RMS has a set similar to magnum force
[Re: n20mstr]
#2620337
02/12/19 05:20 PM
02/12/19 05:20 PM
Posts: 619 nj
JAMESDART
nj
[quote=geo.]
The double adj upper arms, I don't see anyone else making them ? Guess its stock stuff for another season lol SPC?
[Re: n20mstr]
#2620354
02/12/19 05:46 PM
02/12/19 05:46 PM
Posts: 339 Gilroy,CA.
mopardude318
Gilroy,CA.
I'm sorry you fell victim to that long haired rock star wannabe Ron character.
Give Bill at RMS a call.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
[Re: mopardude318]
#2620362
02/12/19 06:08 PM
02/12/19 06:08 PM
Posts: 34,871 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Many moons ago, tried to do that to me..
CC company took his money, then he wanted to ship asap , told him thanks but no thanks .
I've 1st hand witnessed at least 4 of his front ends busted
I'll steer clear ( no pun intended ) of his products now and forever
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: bigdad]
#2620394
02/12/19 06:36 PM
02/12/19 06:36 PM
jcc
Bitopia
Not sure anybody can dispute Bill at RMS was/is the longtime leader/innovator on quality aftermarket front ends for mopars. Only thing that bothers me more those without enough talent to design their own better"mousetrap", and then hide behind a copy, is someone who makes the mistake of copying a bad design. I never stopped shaking my head on Bill's "upgraded" rear mopar 4 link suspension offering, and have seldom bit my tongue in that regard, but to resort to copying it, speaks volumes to me. The comment above is in reference to the gerst rear 4 link suspension system. While on the topic: "A triangulated 4 link uses short and long control arms set at opposing angles to help keep the rear axle located and relies on a separate spring and shock for controlling travel over bumps and body roll control. Maybe a little better than leaf springs the 4-link still has issues with suspension bind in cornering as the upper and lower arms travel in different arcs. To compensate for this GM control arms are flimsy with rubber bushings to allow a lot of flex for a smoother ride but that means loose and lousy performance. When you make these arms solid and stiff plus add stiffer bushings it actually creates a worse bind situation and can cause a 4-link car to become more twitchy, less predictable, throw off the front suspension travel and lose traction everywhere." From: http://www.speedtechperformance.com/inde...prod/prd613.htmAND GM and Fox body's share a similar triangulated 4 link design mentioned above.
[Re: n20mstr]
#2620407
02/12/19 07:06 PM
02/12/19 07:06 PM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
I put a Alterkation on my Valiant ..
They are similar but, the Geerst one .. IMO
Is nicer
And it was considerably less and Carl will answer any question you have at any time .. his customer service is top notch
So far been 126.5 mph with it and it drives perfect and aligned with ease everyone that looks at says is nice
so I can very easily compare and recommend
[Re: n20mstr]
#2620500
02/12/19 09:43 PM
02/12/19 09:43 PM
Posts: 20,159 PA.
pittsburghracer
"Little"John
"Little"John
PA.
He sure does seem to have a nice website. At least he has that going for him.
[Re: bigdad]
#2620541
02/12/19 10:52 PM
02/12/19 10:52 PM
moparpollack
Lil Herman
Lil Herman
85086
I'll steer clear ( no pun intended ) of his products now and forever Backing into a parking space and down ago the ground the car went.
[Re: n20mstr]
#2620608
02/13/19 01:17 AM
02/13/19 01:17 AM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
I'm not a front-end Guru but would it be possible to get enough adjustment out of adjustable upper control arms to get things. Adjusted and low enough without using a drop spindle.. or would shock length become an issue I wouldn't think you would require much travel upfront
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: n20mstr]
#2620619
02/13/19 01:33 AM
02/13/19 01:33 AM
Posts: 20,167 Park Forest, IL
slantzilla
Park Forest, IL
The problem with some of these systems is the geometry is so far off parts bind up, then "BANG!".
I know that was the case with the POS AJE setup I had. It was so crappy you couldn't keep it from binding with 2" of travel.
