MAGNUM FORCE WHAT THE ????
#2619960
02/11/19 07:47 PM
02/11/19 07:47 PM
Posts: 4,673 On the parachute mount
n20mstr
Called on Nov 19th, ordered drop spindles and upper control arms. Paid in full.
As of today, NO product delivered, NO email answered, NO phone call returned.
Get an answering machine ??
About to just get the money back from my bank and buy the stuff from someone else
....BAD A$$ STREET CAR.....
Re: MAGNUM FORCE WHAT THE ????
[Re: n20mstr]
#2619966
02/11/19 07:57 PM
02/11/19 07:57 PM
Posts: 22,695 Bitopia
jcc
Bitopia
"MAGNUM FORCE WHAT THE ????" The State of Magnum Force is Strong.
[Re: geo.]
#2620030
02/11/19 10:47 PM
02/11/19 10:47 PM
n20mstr
Staff too busy being on tv?
You're doing the right thing, they can't expect you to wait forever.
I'm sure someone will suggest a better source. The double adj upper arms, I don't see anyone else making them ? Guess its stock stuff for another season lol
[Re: n20mstr]
#2620038
02/11/19 10:59 PM
02/11/19 10:59 PM
Posts: 2,826 NY usa
540challenger
NY usa
I'm sure someone will suggest a better source. The double adj upper arms, I don't see anyone else making them ? Guess its stock stuff for another season lol Hotchkis has some nice ones but expensive, and I think RMS has a set similar to magnum force
[Re: n20mstr]
#2620337
02/12/19 05:20 PM
02/12/19 05:20 PM
Posts: 619 nj
JAMESDART
nj
[quote=geo.]
The double adj upper arms, I don't see anyone else making them ? Guess its stock stuff for another season lol SPC?
[Re: n20mstr]
#2620354
02/12/19 05:46 PM
02/12/19 05:46 PM
Posts: 339 Gilroy,CA.
mopardude318
Gilroy,CA.
I'm sorry you fell victim to that long haired rock star wannabe Ron character.
Give Bill at RMS a call.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
[Re: mopardude318]
#2620362
02/12/19 06:08 PM
02/12/19 06:08 PM
Posts: 34,870 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Many moons ago, tried to do that to me..
CC company took his money, then he wanted to ship asap , told him thanks but no thanks .
I've 1st hand witnessed at least 4 of his front ends busted
I'll steer clear ( no pun intended ) of his products now and forever
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: bigdad]
#2620394
02/12/19 06:36 PM
02/12/19 06:36 PM
jcc
Bitopia
Not sure anybody can dispute Bill at RMS was/is the longtime leader/innovator on quality aftermarket front ends for mopars. Only thing that bothers me more those without enough talent to design their own better"mousetrap", and then hide behind a copy, is someone who makes the mistake of copying a bad design. I never stopped shaking my head on Bill's "upgraded" rear mopar 4 link suspension offering, and have seldom bit my tongue in that regard, but to resort to copying it, speaks volumes to me. The comment above is in reference to the gerst rear 4 link suspension system. While on the topic: "A triangulated 4 link uses short and long control arms set at opposing angles to help keep the rear axle located and relies on a separate spring and shock for controlling travel over bumps and body roll control. Maybe a little better than leaf springs the 4-link still has issues with suspension bind in cornering as the upper and lower arms travel in different arcs. To compensate for this GM control arms are flimsy with rubber bushings to allow a lot of flex for a smoother ride but that means loose and lousy performance. When you make these arms solid and stiff plus add stiffer bushings it actually creates a worse bind situation and can cause a 4-link car to become more twitchy, less predictable, throw off the front suspension travel and lose traction everywhere." From: http://www.speedtechperformance.com/inde...prod/prd613.htmAND GM and Fox body's share a similar triangulated 4 link design mentioned above.
[Re: n20mstr]
#2620407
02/12/19 07:06 PM
02/12/19 07:06 PM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
I put a Alterkation on my Valiant ..
They are similar but, the Geerst one .. IMO
Is nicer
And it was considerably less and Carl will answer any question you have at any time .. his customer service is top notch
So far been 126.5 mph with it and it drives perfect and aligned with ease everyone that looks at says is nice
so I can very easily compare and recommend
[Re: n20mstr]
#2620500
02/12/19 09:43 PM
02/12/19 09:43 PM
Posts: 20,157 PA.
pittsburghracer
"Little"John
"Little"John
PA.
He sure does seem to have a nice website. At least he has that going for him.
[Re: bigdad]
#2620541
02/12/19 10:52 PM
02/12/19 10:52 PM
moparpollack
Lil Herman
Lil Herman
85086
I'll steer clear ( no pun intended ) of his products now and forever Backing into a parking space and down ago the ground the car went.
[Re: n20mstr]
#2620608
02/13/19 01:17 AM
02/13/19 01:17 AM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
I'm not a front-end Guru but would it be possible to get enough adjustment out of adjustable upper control arms to get things. Adjusted and low enough without using a drop spindle.. or would shock length become an issue I wouldn't think you would require much travel upfront
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: n20mstr]
#2620619
02/13/19 01:33 AM
02/13/19 01:33 AM
Posts: 20,165 Park Forest, IL
slantzilla
Park Forest, IL
The problem with some of these systems is the geometry is so far off parts bind up, then "BANG!".
I know that was the case with the POS AJE setup I had. It was so crappy you couldn't keep it from binding with 2" of travel.
[Re: WHITEDART]
#2620708
02/13/19 10:52 AM
02/13/19 10:52 AM
n20mstr
I'm not a front-end Guru but would it be possible to get enough adjustment out of adjustable upper control arms to get things. Adjusted and low enough without using a drop spindle.. or would shock length become an issue I wouldn't think you would require much travel upfront Upper control arms will fix it for sure. I wanted to get the Magnumforce ones that are double adj. But now so turned off im about to dispute the charge with my bank and get the money back that way. I use as much front travel as I can get, control it with the shocks. I have Santuffs up front.
[Re: cudadoug]
#2620709
02/13/19 10:54 AM
02/13/19 10:54 AM
n20mstr
Food for thought: If I were looking for something “trick” in a Mopar front suspension, I’d sure be talking to the super stock chassis guys before I’d talk to any parts peddlers that are clueless about what they sell.
Mandella, Keir and such have forgotten more about FAST Mopar suspensions that most will ever know. In theory sounds good, BUT these guys usually don't hand that info out so easily. I have crawled under some SS Hemi darts and Cudas. You can tell that the front has been fudged with, but it does still look like "stock" parts as NHRA requires.
[Re: n20mstr]
#2620822
02/13/19 03:48 PM
02/13/19 03:48 PM
Posts: 5,387 Pikes Peak Country
TC@HP2
Pikes Peak Country
Most, if not all, tubular upper control arms are built with additional caster in them. The only real advantage of the MF double adjustable is they can be adjusted on the car without taking them apart. If you buy heim ended arms, you should be able to rough in extra caster over stock prior to assembly and use the eccentrics to finalize it. Once its set, you likely won't be changing it regularly anyway. But, you could look also at SPC if you want the on car adjustability. https://www.spcalignment.com/component/content/article?id=370Other places sell the drop spindles too, like Firm Feel, PST, and probably a few others.
[Re: n20mstr]
#2620879
02/13/19 06:05 PM
02/13/19 06:05 PM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Drop spindles lower the front of the car
[Re: bigdad]
#2620953
02/13/19 09:09 PM
02/13/19 09:09 PM
Posts: 1,823 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
Drop spindles lower the front of the car Thanks I thought if the spindles were dropped it would raise the car. My bad. I need taller front tires to get oil pan clearance. So that's out. Thankyou
[Re: Kern Dog]
#2620968
02/13/19 09:33 PM
02/13/19 09:33 PM
jcc
Bitopia
Magnum Farce is the HARBOR FREIGHT of suspension components. At their pricing? I was thinking more Bernie Madoff. Actually I wish them no malice, but one has to admit, they got the "sizzle" and marketing happening.
[Re: jcc]
#2620988
02/13/19 10:01 PM
02/13/19 10:01 PM
Posts: 4,974 new jersey usa
11secdart
new jersey usa
Hey Tony, doesn't QA1 sell tubular A arms? on another note a friend of mine actually from your neck of the woods bought a MF tubular front end for his big block Dart years ago and had many problems with the installation. Its actually in another friends Dart now but again it took some mods to make it work.
[Re: AndyF]
#2621129
02/14/19 03:27 AM
02/14/19 03:27 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Your deposit was spent on hair care products..... AND T-shirts that are a size or two smaller than he should be wearing.
[Re: n20mstr]
#2621178
02/14/19 10:52 AM
02/14/19 10:52 AM
Posts: 4,457 Washington
madscientist
Washington
Damn you guys are BRUTAL! Truthful, but brutal.
[Re: J_BODY]
#2621236
02/14/19 01:07 PM
02/14/19 01:07 PM
Posts: 10,020 MN
JERICOGTX
MN
Your deposit was spent on hair care products..... Oh Andy.... so technical, so serious. Then this falls out! Was thinking the same thing Jay. had to do a double take on who posted it. LOL.
69 GTX
68 Road Runner
[Re: 11secdart]
#2621316
02/14/19 03:32 PM
02/14/19 03:32 PM
TC@HP2
Pikes Peak Country
Hey Tony, doesn't QA1 sell tubular A arms? on another note a friend of mine actually from your neck of the woods bought a MF tubular front end for his big block Dart years ago and had many problems with the installation. Its actually in another friends Dart now but again it took some mods to make it work. QA1 does make tubular arms, upper and lower for that matter, but they are the bushing style upper arms. I believe MF, Hotchkis, and SPC are the only companies out there making units that can be adjusted on the car. One could make a set with swedged tubes and ball joint plates from the Speedway Motors catalog, but this would require changing the arm mounting style to a through stud arrangement like a GM.
[Re: geo.]
#2622348
02/16/19 10:53 PM
02/16/19 10:53 PM
jcc
Bitopia
Your point is well taken. Contrary to what most, I believe feel, I am unconvinced ANY of the aftermarket UCA's offer improved rigidity over the OEM UCA, welds or not. Their main attributes are the better caster mentioned, and extra clearance for coil over options, IMO. And the cost of stamping an improved OEM UCA likely is not cost justifiable for our market just to gain caster. Besides, om the quality UCA's, no welds have been reported to be failing in normal use. I also am a believer one can improve typical aftermarket CA's for rigidity, case in point, Pic #7: https://board.moparts.org/ubbthreads/ubbt...tml#Post1665054
[Re: RThunder]
#2622488
02/17/19 11:37 AM
02/17/19 11:37 AM
n20mstr
I talked to Magnum Force 2 weeks ago. They just moved from CA to NV. I bought an XRT suspension 6 years ago and just recently found out the sway bar arms were too short. They are supposed to be be calling me back with a price for the correct arms. Still waiting.... At that time they were just setting up new shop??? Moved ? And setting up a new shop ? But they took my money three months ago and now act like ?? We dont have a shop set up now ? They wont even call me back. I just called the bank and disputed the charge. Ill buy the PST arms. Magnum force never again...
[Re: Kern Dog]
#2622508
02/17/19 01:13 PM
02/17/19 01:13 PM
Posts: 13,185 aZLiViN
J_BODY
aZLiViN
Wonder if they moved to escape the BULLSHI* regulations and taxes of this state. I'm no fan of this company but if they left for those reason, I applaud them. The assclow Liberal politicians here are chasing the middle class and the small business people away and they don't seem to either understand why or care. The Smith family (Pro Trans) just moved their business to Texas for many reasons you mentioned. I’ll miss not having them a few short hours drive away.
[Re: J_BODY]
#2623206
02/19/19 03:11 AM
02/19/19 03:11 AM
Posts: 263 CA, USA
JcodeCharger
CA, USA
Wonder if they moved to escape the BULLSHI* regulations and taxes of this state. I'm no fan of this company but if they left for those reason, I applaud them. The assclow Liberal politicians here are chasing the middle class and the small business people away and they don't seem to either understand why or care. The Smith family (Pro Trans) just moved their business to Texas for many reasons you mentioned. I’ll miss not having them a few short hours drive away. You and me both. On another note. My back half was done by Hansens race cars and he has done many Superstock cars over the years (mine is set up like the Heli-Hemi Dart he did years ago) and he is pretty forthcoming about front end set up. Those cars are surprisingly stock. He has shared that, while being a gentleman about it, the stock Mopar technology is hard to beat. I used QA1 stuff on the front of my car and we aligned it like a stocker except we shortened the lower strut rod (its adjustable) slightly and achieved 8 degrees of caster with the car 1/4" off the bump stop. I am very happy with the quality of the QA1 front suspension.
68 twin turbo Dart 8.19 so far 70 Swinger 360 69 Roadrunner 383 4 speed 69 Mod Top Satellite 383 auto 69.5 A12 Super Bee 4 speed 70 T/A Challenger 70 FC7 Duster 340 4 speed 70 FJ5 Superbird 68 Hemi 4 speed Roadrunner 71 Duster W2 340
[Re: n20mstr]
#2623274
02/19/19 12:41 PM
02/19/19 12:41 PM
Posts: 8,861 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
the stock Mopar technology is hard to beat. That's a well-known fact.
