Hemi water block (not mine) #2619799
02/11/19 02:27 PM
02/11/19 02:27 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Pls delete if not allowed. Not mine and I dunno whos it is.
Super stock block with no lifter bore$.
Check the packaging date...that's the last of them, right before the switch to the World style.
It's alot, but it's less than the recent Jegs auctions.
https://www.ebay.com/itm/426-hemi-block/113632795629?hash=item1a750adbed:g:7NEAAOSwZ65cYY3k:rk:3:pf:1&frcectupt=true
Re: Hemi water block (not mine) [Re: ZIPPY] #2619815
02/11/19 02:53 PM
02/11/19 02:53 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Thanks Zippy. I won't look as proper as an old block but it's mo better than those ones with the core plugs in the front.
2011 Drag Pak Challenger
Re: Hemi water block (not mine) [Re: ZIPPY] #2619822
02/11/19 03:07 PM
02/11/19 03:07 PM
central il.
second 70 Offline
second 70  Offline
central il.
Already gone $4950 shipped.
Re: Hemi water block (not mine) [Re: ZIPPY] #2619824
02/11/19 03:11 PM
02/11/19 03:11 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Did you see the do not exceed 4.34 bore sticker?
Re: Hemi water block (not mine) [Re: ZIPPY] #2619838
02/11/19 03:29 PM
02/11/19 03:29 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
If I remember correctly Cummins added those stickers around '05. Some of them could go bigger but it was a cya thing. Better to start with a megablock for big bore apps.
Re: Hemi water block (not mine) [Re: dthemi] #2619839
02/11/19 03:32 PM
02/11/19 03:32 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Yes, it must be a non-siamese block. Not sure that I will use it but I don't want to have to go looking for one if I need one.
Re: Hemi water block (not mine) [Re: rickseeman] #2619841
02/11/19 03:41 PM
02/11/19 03:41 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Yes...internal MP lingo was "water block" for non-siamese.
I thought everyone called them that...wrong....
Hope it's a good one for you!
Re: Hemi water block (not mine) [Re: ZIPPY] #2619866
02/11/19 04:15 PM
02/11/19 04:15 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I'm hoping that it's a little lighter than the later blocks but if I remember right these are very heavy too.
Re: Hemi water block (not mine) [Re: rickseeman] #2619892
02/11/19 05:13 PM
02/11/19 05:13 PM
Sweden
MikeN Offline
MikeN  Offline
Sweden
I checked the 2007 MP catalog, there were no waterblocks without tappet machining. One picture show the casting number with the "Mopar" logotype the siamese blocks had. Its probably part no P5007648AB in a mismarked box.
Re: Hemi water block (not mine) [Re: ZIPPY] #2619903
02/11/19 05:32 PM
02/11/19 05:32 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
You might enjoy hearing about the iron hemi heads with no pushrod holes in them, which were catalogued as stock replacement heads and yet were nowhere near being suitable for such an application laugh
That was the only iron head available for years, and I heard only one complaint....from a guy building a street engine.
There have been times when the catalog was deliberately incorrect and was not telling the whole story. They did all kinds of stuff like that for super stock where they could. Racers have changed lifter locations for quite awhile.
Re: Hemi water block (not mine) [Re: ZIPPY] #2619908
02/11/19 05:43 PM
02/11/19 05:43 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I think all those guys was 2" spread lifter bores now.
Re: Hemi water block (not mine) [Re: rickseeman] #2619928
02/11/19 06:35 PM
02/11/19 06:35 PM
central il.
second 70 Offline
second 70  Offline
central il.
If the pictures on the listing are the block that got sold it is a Siamese megablock. You can see Mopar cast above the 2468330. The water blocks didn’t have the mopar casting.
Mike
Re: Hemi water block (not mine) [Re: ZIPPY] #2619993
02/11/19 08:53 PM
02/11/19 08:53 PM
In The Hills
jughed Offline
jughed  Offline
In The Hills
...block part #s.
(FWIW..the underlined block is what i have and this sheet came with it)
Re: Hemi water block (not mine) [Re: ZIPPY] #2620261
02/12/19 02:03 PM
02/12/19 02:03 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
I saw with my own eyes a 4.5 siamese block, sold as 4.5 bore, get bored .06 without sonic testing, and hit the water LOL. So it wasn't safe to run where it started life. There was an entire run of those blocks not worth having.
Re: Hemi water block (not mine) [Re: dthemi] #2620305
02/12/19 04:33 PM
02/12/19 04:33 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
I heard about the nightmare batch, and what a disaster.
I believe they had the wrong bore spacing! By now I would hope all those were scrapped..... Hopefully this one isn't one of those
Re: Hemi water block (not mine) [Re: ZIPPY] #2621449
02/14/19 10:22 PM
02/14/19 10:22 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
The block got here. The box didn't. I don't guess it matters. It doesn't appear to be the part number on the box. This is 4.19 siamese with no lifters. I will sonic check this weekend. It weighed 296 lbs at 4.19 with no lifters.
Re: Hemi water block (not mine) [Re: ZIPPY] #2621693
02/15/19 02:53 PM
02/15/19 02:53 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Could very well have been mispacked/wrong part in the box...happened all the time. Hope it is a good one for you Rick
