Re: 69 woodgrain wheel hardware
[Re: rarefish]
#2618233
02/07/19 01:24 PM
02/07/19 01:24 PM
Posts: 267 New Jersey
69Chrgr
New Jersey
To me it sounds like you have all the parts. You will need the attaching screws for the horn switch and adapter. Im just wondering if the switch screws have some kind of insulator bushing?
[Re: 69Chrgr]
#2618284
02/07/19 02:57 PM
02/07/19 02:57 PM
Posts: 2,757 Gilbertsville, PA 19525
Pntastar69
I have a complete 69 woodgrain wheel. wheel, adapter, horn contact switch, and button. I have no harware other than the steering shaft nut. Is the hardware special? Year one has with there repro wheels it says " must use original hardware" I'm not sure if there are insulators? or anything else special. Any help would be appreciated on what it consists of and where to get it.
Thanks Duane U have everything you need. Just add normal hardware, no insulators required.
[Re: NANKET]
#2618693
02/08/19 03:28 PM
02/08/19 03:28 PM
69Chrgr
New Jersey
1) The switch screws to the adapter that holds the horn pad. 2) The switch screws to the wheel.
As stated no insulators on this wheel
You need a washer for the large but. Thank you!
