Rear window trim clip template 68-70 B body #2616932
02/04/19 04:46 PM
02/04/19 04:46 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Is there a template for the layout of the trim clips on the back glass of a 68-70 B Body?
I'm about to have the window out, and incase I lose my notes I'd like to know if there is a suggested placement for the clips.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Rear window trim clip template 68-70 B body [Re: AlexP] #2616935
02/04/19 04:57 PM
02/04/19 04:57 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I'm pretty sure b-bodies have the hole stamped out on the inner panel... package tray, unless I'm mixing that up with e-bodies. That would get you good on the bottom. One the rest I like to space them out even, just not too close to the corners or where they meet top center/
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Rear window trim clip template 68-70 B body [Re: AlexP] #2616950
02/04/19 05:17 PM
02/04/19 05:17 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
No stamping for the holes on the rear glass like the front. When I cut out my rear deck filler panel, I saved the old one to use as a template.
69 GTX 68 Road Runner
