Need A833 help
#2615642
02/01/19 05:09 PM
02/01/19 05:09 PM
Posts: 33 Ontario, Canada
Todd Lepine
Ontario, Canada
Hello everyone, Wondering if someone could give me an idea how to find out what this came from.. Not sure if this is enough info. Thanks
Todd Lepine, (705)977-1502
Re: Need A833 help
[Re: A12]
#2615669
02/01/19 06:19 PM
02/01/19 06:19 PM
Todd Lepine
Ontario, Canada
I suppose the Bell housing is the key and then the spline Configuration? It's in my car right now and is not the original obviously.
Re: Need A833 help
[Re: 340cpe]
#2615745
02/01/19 10:10 PM
02/01/19 10:10 PM
Posts: 21,819 Kirkland, Washington
Pacnorthcuda
Ok enlighten me I thought the last 6 numbers were purely a sequence number. How do the fives signify a Plymouth? How would you know if it were a dodge? I'm wondering the same thing.
Re: Need A833 help
[Re: Pacnorthcuda]
#2615794
02/02/19 12:27 AM
02/02/19 12:27 AM
Todd Lepine
Ontario, Canada
I haven't had a chance yet to look at the Casting Numbers but can this indicate any significance of HP? How can you tell what spline count you have without taking the transmission out of the car?
Re: Need A833 help
[Re: Todd Lepine]
#2615827
02/02/19 01:19 AM
02/02/19 01:19 AM
Posts: 21,498 N.E. OHIO, USA
A12
N.E. OHIO, USA
I haven't had a chance yet to look at the Casting Numbers but can this indicate any significance of HP? How can you tell what spline count you have without taking the transmission out of the car? No need to take the trans apart if it is off of the car and you can see the front shaft with the clutch removed. The spline count is the part of the front shaft that inserts into the clutch center. The 18 spline is the shaft with the "V" taper at the end of the splines. And the 18 spline shaft is larger and longer......."that's what she.......... Mike
Re: Need A833 help
[Re: A12]
#2615855
02/02/19 02:38 AM
02/02/19 02:38 AM
Posts: 17,515 Las Vegas, NV
6bblgt
Las Vegas, NV
I see " 5", is that what they both are? 1968 Lynch Rd. VIN sequence numbers are arranged in Plymouth B-body and Dodge B-body "batches" 8A205095 or 8A205096 are both Plymouths but with my limited amount of 1968 Lynch Rd. data I can not confirm whether 8A206095 or 8A206096 are Dodges or Plymouths
Re: Need A833 help
[Re: Todd Lepine]
#2615856
02/02/19 02:39 AM
02/02/19 02:39 AM
6bblgt
Las Vegas, NV
I haven't had a chance yet to look at the Casting Numbers but can this indicate any significance of HP? How can you tell what spline count you have without taking the transmission out of the car? casting numbers are the same
Re: Need A833 help
[Re: 6bblgt]
#2615899
02/02/19 11:06 AM
02/02/19 11:06 AM
Todd Lepine
Ontario, Canada
Yes both 5. Sorry about the late response.. out for the night. Ok the trans is in the car at the moment so it'll be a mystery for now. Well if theres anyone out there with Vin seqence:
205095, I have your A833.. Thanks guys for all your help Toad
Re: Need A833 help
[Re: Pacnorthcuda]
#2616226
02/03/19 12:01 AM
02/03/19 12:01 AM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
Ok enlighten me I thought the last 6 numbers were purely a sequence number. How do the fives signify a Plymouth? How would you know if it were a dodge? I'm wondering the same thing. Certain members have constructed VIN databases that show that VINs were created in batches. This how some people can tell if your TA engine was in a TA or an AAR.
