External Voltage regulator 67 belvedere
#2615237
01/31/19 07:32 PM
01/31/19 07:32 PM
Posts: 1,548 Michigan
Kiddart
Hi men and women of excellence!!
a simple question but a required question. we are transplanting a 05 gen 3 into a 67 belv the alternator for that year is external regulator and or controlled by the PCM. if we run the pig tail in and out of the current voltage regulator in the car we should be just fine correct? as I plan to do this with my 74 dart as well with my swap. I have read this is doable. true or false??
thank you all for your knowledge!!
Thank you Kiddart
Re: External Voltage regulator 67 belvedere
[Re: Kiddart]
#2615332
01/31/19 11:06 PM
01/31/19 11:06 PM
Posts: 3,101 cincinnati ohio
mcat4321
cincinnati ohio
yes and no.. you will need a later model adustable regulator.. available on e-bat i wired my independent , i have a 12v keyed run to one of the field wires
[Re: mcat4321]
#2615334
01/31/19 11:09 PM
01/31/19 11:09 PM
mcat4321
cincinnati ohio
yes and no.. you will need a later model adustable regulator.. available on e-bat i wired my independent , i have a 12v keyed run to one of the field wires https://www.ebay.com/itm/New-Adjustable-HD-External-Voltage-Regulator-Chrysler-Dodge-Plymouth-1970-87/263796435690?_trkparms=aid%3D555018%26algo%3DPL.SIM%26ao%3D1%26asc%3D55992%26meid%3D08d1f9d13fd449418cc50218b04650b4%26pid%3D100005%26rk%3D2%26rkt%3D2%26sd%3D142267138079%26itm%3D263796435690&_trksid=p2047675.c100005.m1851
[Re: Kiddart]
#2615518
02/01/19 11:45 AM
02/01/19 11:45 AM
Kiddart
Sweet, so I will just update his voltage regulator to the one like in my 74 dart and we are rolling!! thank you everyone
Thank you Kiddart
[Re: Kiddart]
#2616675
02/04/19 12:56 AM
02/04/19 12:56 AM
Posts: 112 Michigan
ghinmi
Yep, external regulator works great on the early gen3 hemi alternators. At some point they changed to pwm control and the external regulator will not work. I forget the exact year.
1975 Jeep Cherokee compound turbo 5.7 Hemi/6 speed AutoX/Drag/Street. 9.97 @ 140 slicks, 10.74 in autox trim
[Re: Kiddart]
#2616836
02/04/19 01:17 PM
02/04/19 01:17 PM
Kiddart
I will work on that for you Goody
Thank you Kiddart
[Re: Kiddart]
#2617545
02/05/19 11:20 PM
02/05/19 11:20 PM
Kiddart
How's the new size goody????
much better!!!! sorry
Thank you Kiddart
