Re: 1979 LiL Red truck electrical Q
[Re: hemienvy]
#2611766
01/24/19 08:04 PM
01/24/19 08:04 PM
Posts: 273 WV
Danny
WV
Well i didnt realize that they do blink, i didnt know that, had to go out in check
[Re: hemienvy]
#2612020
01/25/19 01:08 PM
01/25/19 01:08 PM
RWG75
RWG75
This came up recently in a conversation about converting to LEDs and the short answer is that ground for one function is through the lead for the other function. A thing you may not have noticed yet: headlights off, the front turn sig and side marker blink in unison. Marker lights on and the turn sig and the marker alternate. The marker will come on when either lead is supplying 12v and will turn off when both leads supply 12v. I haven't tried it but I think if you yank the turn sig and flasher relays, it should kill the front markers. As in: the front markers ground back through the turn sig circuit. edit: dug up the thread, reply #3 explains the wiring https://ramchargercentral.com/vehicle-help/led-side-marker-help/
[Re: hemienvy]
#2612384
01/26/19 01:12 AM
01/26/19 01:12 AM
Posts: 7,828 east side of Ohio
basketcase
east side of Ohio
the fender lights blink alternately with the turn signals in the grill. The marker part of the light does not stay lite, so no need for a bulb with two filaments.
1981 Dodge D150 360 auto
[Re: hemienvy]
#2612595
01/26/19 03:07 PM
01/26/19 03:07 PM
Posts: 14 Colorado
Stroller
Colorado
The bulb plugs into the socket. The socket pig tail plugs into the harness where it shares a common ground.
3 things a man should never borrow: Guns, another mans mopar or his wife.
[Re: redraptor]
#2612954
01/27/19 10:09 AM
01/27/19 10:09 AM
Posts: 8,666 Buford, GA
I_bleed_MOPAR
Buford, GA
From his initial post I think he was just curious as to how the light worked with no ground circuit. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
