CASCAR vs 6.1 Intake. #2607944
01/17/19 06:07 AM
01/17/19 06:07 AM
Australia
aus370 Offline OP
aus370  Offline OP
Australia
Bit of a hypothetical here , on an injected 392 cube engine that can make power past 7000 rpm , would there be an advantage of the CASCAR intake over a well ported 6.1 .
Re: CASCAR vs 6.1 Intake. [Re: aus370] #2608049
01/17/19 01:40 PM
01/17/19 01:40 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
My opinion would be that the Cascar will probably make more power than the 6.1 intake over 6k because of the shorter runners. How much not sure.
Re: CASCAR vs 6.1 Intake. [Re: aus370] #2610896
01/23/19 06:07 AM
01/23/19 06:07 AM
Australia
aus370 Offline OP
aus370  Offline OP
Australia
Thanks your opinion is important , thoughts on this . Is it possable the unequal length runners of the casscar could loose power at some point , or is it less important with a dry manifold.
Re: CASCAR vs 6.1 Intake. [Re: aus370] #2610899
01/23/19 06:44 AM
01/23/19 06:44 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
I would imagine that the 6.1 intake losing power after 6800 rpm.
The CASCAR should make power way above that rpm range due to being a single plane.
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: CASCAR vs 6.1 Intake. [Re: RylisPro] #2610901
01/23/19 07:34 AM
01/23/19 07:34 AM
Australia
aus370 Offline OP
aus370  Offline OP
Australia
The 6.1 is also a single plain manifold . from what i understand it's the longer runners of the 6.1 that limit it's high rpm power.
Re: CASCAR vs 6.1 Intake. [Re: aus370] #2611469
01/24/19 10:31 AM
01/24/19 10:31 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
6700-6900 RPM range is your cut off point.... Duration @ 50 effects the 6.1 more.
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
