1968 383 with stock intake carb?? #2610641
01/22/19 08:29 PM
01/22/19 08:29 PM
O
otter440 Offline OP
otter440  Offline OP
O
was wondering which edelbrock carb would work on stock intake and size to use not very mechanical Thanks
Re: 1968 383 with stock intake carb?? [Re: otter440] #2610657
01/22/19 08:49 PM
01/22/19 08:49 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Does Edelbrock offer a 600-625 AVS-type carb? That would be very close to the Carter AVS the '68-69 383 4-bbl cars came with.
EDIT: They make some different models of the AVS 650... close enough.
What I don't know is if their mechanical-choke version will work with the OEM choke device, or if you'd need to use their electric-choke model (assuming you still want to have a choke).
Re: 1968 383 with stock intake carb?? [Re: otter440] #2610742
01/22/19 11:00 PM
01/22/19 11:00 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
the throttle bores on the edelbrock 600's are identical to the stock avs. the edelbrock 650's are closer to venturi size of the stock carb. i'd do a 650.
Re: 1968 383 with stock intake carb?? [Re: lewtot184] #2610772
01/22/19 11:39 PM
01/22/19 11:39 PM
I'd suggest an eddy 1406 (600 cfm). I see used ones regularly for reasonable money. Highly likely you can get one in good shape just rekit it.
Re: 1968 383 with stock intake carb?? [Re: otter440] #2610779
01/22/19 11:49 PM
01/22/19 11:49 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
"not very mechanical" tells me rebuilding a carb is probably not in his wheelhouse.
Edelbrock has gotten real proud of their stuff lately, sad because it's generally decent stuff. Summit has them, $345 for a new 1406, $312 for a factory refurbished one. You can find a third party reman 1406 on Amazon for much less.
Don't be the exception.
Re: 1968 383 with stock intake carb?? [Re: Supercuda] #2610868
01/23/19 03:31 AM
01/23/19 03:31 AM
there is a fresh post on FABO (eddy 1406) for $150+ the ride. The add has a good "feel" to it.
Re: 1968 383 with stock intake carb?? [Re: otter440] #2610895
01/23/19 05:44 AM
01/23/19 05:44 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
Here is a link to the AVS2 650 cfm,electric choke,standard finish(not shiny):
https://www.summitracing.com/parts/edl-1906/overview/
The manual choke version is about $30 less,it might work with the OE choke thermostat,but electric would be a good replacement IMO.
We just put one on an Olds 350,replacing the same that had a manual choke.(The manual version can not be retro fitted with an electric choke like the AFB Performer series)
