Re: 1968 383 with stock intake carb??
[Re: otter440]
#2610657
01/22/19 08:49 PM
01/22/19 08:49 PM
BradH
Does Edelbrock offer a 600-625 AVS-type carb? That would be very close to the Carter AVS the '68-69 383 4-bbl cars came with.
EDIT: They make some different models of the AVS 650... close enough.
What I don't know is if their mechanical-choke version will work with the OEM choke device, or if you'd need to use their electric-choke model (assuming you still want to have a choke).
[Re: lewtot184]
#2610772
01/22/19 11:39 PM
01/22/19 11:39 PM
RapidRobert
I'd suggest an eddy 1406 (600 cfm). I see used ones regularly for reasonable money. Highly likely you can get one in good shape just rekit it.
[Re: otter440]
#2610779
01/22/19 11:49 PM
01/22/19 11:49 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
"not very mechanical" tells me rebuilding a carb is probably not in his wheelhouse.
Edelbrock has gotten real proud of their stuff lately, sad because it's generally decent stuff. Summit has them, $345 for a new 1406, $312 for a factory refurbished one. You can find a third party reman 1406 on Amazon for much less.
[Re: Supercuda]
#2610868
01/23/19 03:31 AM
01/23/19 03:31 AM
RapidRobert
there is a fresh post on FABO (eddy 1406) for $150+ the ride. The add has a good "feel" to it.
[Re: otter440]
#2610895
01/23/19 05:44 AM
01/23/19 05:44 AM
Posts: 1,881 Pittsburgh,PA
RTSrunner
Pittsburgh,PA
Here is a link to the AVS2 650 cfm,electric choke,standard finish(not shiny): https://www.summitracing.com/parts/edl-1906/overview/The manual choke version is about $30 less,it might work with the OE choke thermostat,but electric would be a good replacement IMO. We just put one on an Olds 350,replacing the same that had a manual choke.(The manual version can not be retro fitted with an electric choke like the AFB Performer series)
