Re: 1966 Plymouth Belvedere rear frame brackets #2609228
01/20/19 04:00 AM
01/20/19 04:00 AM
Akron, Ohio
VegasCharger Offline OP
Akron, Ohio
Parting out a '66 Plymouth Belvedere and came across these brackets attached to the rear frame rails near the spring perch boxes. They seem like a factory part, especially the bolts that secure them. Were these trailer hitch brackets? Anchor points for towing?
Any help would be greatly appreciated! beer
Re: 1966 Plymouth Belvedere rear frame brackets [Re: VegasCharger] #2609231
01/20/19 05:24 AM
01/20/19 05:24 AM
They are the stock rear tie downs used for transporting them to the dealers scope
Re: 1966 Plymouth Belvedere rear frame brackets [Re: VegasCharger] #2610097
01/21/19 10:10 PM
01/21/19 10:10 PM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
What else are you parting out from that car?
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
Re: 1966 Plymouth Belvedere rear frame brackets [Re: Cab_Burge] #2610608
01/22/19 07:22 PM
01/22/19 07:22 PM
Akron, Ohio
Akron, Ohio
Okay thanks.
So do the purist put these back on when doing a full resto? Or are they throw away parts?
Thanks again for your help. beer
Re: 1966 Plymouth Belvedere rear frame brackets [Re: mopardude318] #2610609
01/22/19 07:22 PM
01/22/19 07:22 PM
Akron, Ohio
Akron, Ohio
Sent you a PM.
Re: 1966 Plymouth Belvedere rear frame brackets [Re: VegasCharger] #2610625
01/22/19 08:08 PM
01/22/19 08:08 PM
Okay thanks.
shruggy
Its your car, you decide grin
Re: 1966 Plymouth Belvedere rear frame brackets [Re: VegasCharger] #2610719
01/22/19 10:23 PM
01/22/19 10:23 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
On a restoration? Yes Id put them back.
Re: 1966 Plymouth Belvedere rear frame brackets [Re: VegasCharger] #2610800
01/23/19 12:36 AM
01/23/19 12:36 AM
central Florida
VL21 Offline
VL21  Offline
central Florida
Dealer was supposed to remove them in prep.
I know that we never did at 63436.
It takes gasoline to interest me.
