Speedmaster/procomp gen 3 hemi blocks
#2610715
01/22/19 10:06 PM
01/22/19 10:06 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Not in the market for one, but saw they are producing blocks... anyone know anything about them?
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Speedmaster/procomp gen 3 hemi blocks
[Re: Silver70]
#2611298
01/23/19 11:10 PM
01/23/19 11:10 PM
Posts: 1,546 Michigan
Kiddart
does anyone know what a block costs from dealer?
Thank you Kiddart
[Re: WO23Coronet]
#2611464
01/24/19 09:58 AM
01/24/19 09:58 AM
Posts: 1,834 NW Indiana
fbs63
NW Indiana
Anyone know if there are spec's listed anywhere. The description seems generic like it covers all the blocks. The description say's billet caps. Love to know the cylinder wall thickness.I have a 6.4 BGE block that I had Arrington billet main caps,ARP studs and normal machine work done and have almost 3K in it.
[Re: Silver70]
#2611468
01/24/19 10:27 AM
01/24/19 10:27 AM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
5.7 Eagle block part # 53021314DR , any where from 800ish to 1100ish (summit sells them for $850 depending on who and where you go. there are no 03-08 blocks being casted (ANYWHERE) the Speed master block is a reman block ,line bored and honed. When they 1st listed them around X-mass the were 1500 introductory offer. the one I have here has Billet caps and ARP main studs deck is finished at 9.249.....your better off buying the summit version for the 03-08 (SUM-150160) doesn't come with billet caps but it's only $1200.
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
[Re: ric3xrt]
#2614193
01/29/19 06:37 PM
01/29/19 06:37 PM
dogdays
No I think you'll eventually be proven wrong. They make other blocks, the GIII is well within their capabilities. They say 4 bolt splayed caps, not 6 bolt cross bolted, plus thicker sections in some high stress areas. They have an aluminum chevy smallblock for less than 2750, plus other cast iron chevy blocks. Some are in stock, some out. They blew the bottom out of the Oldsmobile head market and likewise last year, the Cleveland head. It seems that they're getting their casting technology down. Machined in the USA. You know what that means, cast and rough machined, probably, in China.
R.
[Re: Silver70]
#2614211
01/29/19 07:16 PM
01/29/19 07:16 PM
Posts: 14,491 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
When they 1st listed them around X-mass the were 1500 introductory offer. the one I have here has Billet caps and ARP main studs deck is finished at 9.249... I take it you bought one of the Speedmaster blocks?
[Re: Silver70]
#2614256
01/29/19 08:48 PM
01/29/19 08:48 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
So a bare early 5.7 block costs more than a brand new eagle short block?
[Re: fast68plymouth]
#2614503
01/30/19 11:39 AM
01/30/19 11:39 AM
ric3xrt
Trumbauersville PA
When they 1st listed them around X-mass the were 1500 introductory offer. the one I have here has Billet caps and ARP main studs deck is finished at 9.249... I take it you bought one of the Speedmaster blocks? I didn't buy it was dropped off here for a build.
[Re: HotRodDave]
#2614504
01/30/19 11:40 AM
01/30/19 11:40 AM
ric3xrt
Trumbauersville PA
So a bare early 5.7 block costs more than a brand new eagle short block? Yeah go figure that logic
[Re: dogdays]
#2614510
01/30/19 11:46 AM
01/30/19 11:46 AM
ric3xrt
Trumbauersville PA
R. They are gearing up for a 6.1 style casting before the end of this year....what they are selling at this point is nothing more then a race prep 5.7 factory block with Billet caps...same as summit but summit does not have the billet caps. They are more than capable to produce a G3 block but at this point they are NOT.....a redesign of the PRW PQX Modular Hemi roller tip rockers is also in the works ,but with 1.8 ratio.
