71 SuperBee gas cap question #2609560
01/20/19 09:55 PM
01/20/19 09:55 PM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
I've purchased a few gas caps for my 71 Bee and no matter if they are NOS or Stant replacements they never sit with the handle horizontal after installing. What gives here???
Car is a B04 build and I even changed the filler tube to a nicer one but same deal. Saw this on another guy's Charger also so it has to be the way the caps are being made.
I've tried two of this P/N even though they were both a little different than each other: NOS MoPar 1970-72 Plymouth Dodge GAS CAP 3466825
And a Stant P/N G47/G806
Thanks Ron
Re: 71 SuperBee gas cap question [Re: RJS] #2609711
01/21/19 01:59 AM
01/21/19 01:59 AM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
Cmon this cap has been keeping me up at night!!! LOL
Ron
Re: 71 SuperBee gas cap question [Re: RJS] #2609905
01/21/19 03:28 PM
01/21/19 03:28 PM
home of the Buckeyes
Butterscotch71 Offline
Lost Title
Lost Title
I don't believe the cap on my original unrestored 71 runner sits level either, but I'd have to check to be sure.
addict:to devote or surrender (oneself) to something habitually or obsessively ....hmmmm
Re: 71 SuperBee gas cap question [Re: Butterscotch71] #2609983
01/21/19 06:00 PM
01/21/19 06:00 PM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
If so when was it built because there is a different cap after April.
Ron
Re: 71 SuperBee gas cap question [Re: RJS] #2610183
01/22/19 12:03 AM
01/22/19 12:03 AM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
Anyone else own a 71 B-Body?
Ron
Re: 71 SuperBee gas cap question [Re: RJS] #2610258
01/22/19 02:33 AM
01/22/19 02:33 AM
Pa.
3
340cpe Offline
340cpe  Offline
Pa.
Mine was a August of 70 build date and that’s the way it is.
Re: 71 SuperBee gas cap question [Re: RJS] #2610313
01/22/19 09:27 AM
01/22/19 09:27 AM
MA
steve70 Offline
steve70  Offline
MA
Hera are a couple pictures of my 71 R/T. I have no idea if it's an original cap but clocks the same as yours. It a September 70 SPD
1970 Challenger T/A 4 speed
Re: 71 SuperBee gas cap question [Re: RJS] #2610338
01/22/19 11:26 AM
01/22/19 11:26 AM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
Thanks for the info. so I guess this is how it wants to be, I still find it strange!!
Ron
Re: 71 SuperBee gas cap question [Re: RJS] #2610364
01/22/19 12:26 PM
01/22/19 12:26 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
71 California RR, same way...
Joe
Re: 71 SuperBee gas cap question [Re: RJS] #2610384
01/22/19 01:21 PM
01/22/19 01:21 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Why do you find it strange on something you never see with the license plate down
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: 71 SuperBee gas cap question [Re: RJS] #2610394
01/22/19 01:42 PM
01/22/19 01:42 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Don't know about '71 B-body gas caps but the '68 '69 caps has a bridge over the center rivet and the location is dictated by the rivet. I would guess the fixture by the OEM supplier was set up to have that in a horizontal position??? Should the '71 gas cap look like this with the bridged cross "handle"???
Re: 71 SuperBee gas cap question [Re: bee1971] #2610397
01/22/19 01:46 PM
01/22/19 01:46 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
And I totally agree. I would think for the most accuracy it would be the correct style cap then maybe the position. If it's the closed cap handle position then maybe heating the rivet enough to "maybe" release some of the rivet tension and off the car on an old stand alone filler neck you could reposition and get that well needed sleep grin wink
Re: 71 SuperBee gas cap question [Re: RJS] #2610442
01/22/19 03:10 PM
01/22/19 03:10 PM
Lost Title
Lost Title
No pictures, but my LA built (Aug 70) runner clocks the same as Steve70s photo. On my survivor St Louis built (Dec 70) runner the handles are vertical.
Re: 71 SuperBee gas cap question [Re: bee1971] #2610504
01/22/19 04:27 PM
01/22/19 04:27 PM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
Because I like things a certain way, any car I've owned since 1977 when the cap was tight the handle would be straight across. Very simple. I am joking when I say I'm losing sleep. Would you be OK if your door lock was twisted in the door or trunk??? I know I wouldn't but that is usually what separates my cars from others.
I wouldn't think the desire for correct isn't a bad thing with a classic car.
Ron
