Page 2 of 3 < 1 2 3 >
#2605905 - 01/13/19 12:17 PM Re: OEM 360 harmonic balancers [Re: moparts]
PHYSIXX Offline
Loc: Edison, New Jersey
I have for sale two OEM 360 harmonic balancers. They both are in great shape and have been cleaned but not painted. There doesn’t appear to be any damage, cracks for stripped threads on either balancer. One does have the front cover seal sleeve pressed on the snout as seen in the picture, while the other does not have one as the original surface looks great. I would like to get $25 for the balancer without the sleeve and $20 for the one with the sleeve.
Edison, NJ
rider1454 at aol.com
#2606088 - 01/13/19 05:12 PM Re: Holley 650 [Re: PHYSIXX]
DusterKid Offline
Loc: Keymar, MD
Holley 650 Carb, Part Number is 4777-7. Has been used very little. The one hole on the linkage side has been drilled out a little. SOLD
Edited by DusterKid (02/11/19 08:08 AM)
Edit Reason: SOLD
#2607081 - 01/15/19 04:00 PM Re: Holley 650 [Re: DusterKid]
Joesixpack Offline
Loc: APACHE JUNCTION AZ
273-318-340-360 aluminum single point distributor lead.nors usa made,have 1$25 plus 4.00 first class
cowgerwilliam035@gmail.com
#2607085 - 01/15/19 04:07 PM Re: Holley 650 [Re: Joesixpack]
Joesixpack Offline
NOS MOPAR DODGE CHALLENGER T/A &PLYMOUTH AAR #2585019--CH922 PRIMARY DISTRIBUTOR LEAD.
273 and 340 dual point distributors 1967-1971
1970 340+6 AAR&TA dual point$45 plus 4.00 first class or 8.00 priority mail small flat rate box
#2607091 - 01/15/19 04:13 PM Re: Holley 650 [Re: Joesixpack]
Joesixpack Offline
THESE ARE THE BOLTS,NUTS AND WASHERS THAT ATTACH YOUR ENGINE MOUNTING BRACKETS(MOTOR MOUNTS) TO THE EARS OF YOUR ENGINE BLOCK
THEY INCLUDE 6 NEW GRADE 8 7/16 -20 FINE THREAD (LIKE FACTORY)ATTACHING BOLTS,6 NEW GRADE 8 LOCKING NUTS, 6 NEW GRADE 5 WASHERS
ARE BRAND NEW! .
THEY WILL FIT ALL V8 SMALL BLOCK ENGINES, 273-318-340-360 AND ALL 1962-1976 DODGE&PLYMOUTH A&B-BODIES IE DART.VALIANT,DUSTER,CUDA,DEMON,CHARGER,ROADRUNNER,GTX,SUPER BEE,CORONET,BELVEDERE,SATELLITE, AND 1970-1974 DODGE CHALLENGERS, PLYMOUTH BARRACUDAS
$10 plus $4.00 first class or 8.00 small priority mail flat rate box
#2607095 - 01/15/19 04:19 PM Re: Holley 650 [Re: Joesixpack]
Joesixpack Offline
2 NOS MOPAR IGNITION CONDENSERS CH-108/3420600
#2875939 WITH PENTASTAR , WITH # ON IT
FITS 273-318-340-360 DODGE&PLYMOUTH CAST IRON/aluminum DISTRIBUTORS, AND 273-340+6 DUAL POINT DISTRIBUTORS. $25 plus 4.00 first class or 8.00 priority mail
#2607724 - 01/16/19 06:06 PM 1976 standard bore 360 short block $150 [Re: moparts]
littleredcoffin Offline
Loc: NH USA
Just in 1976 standard bore 360 short block.Will need a bore..Has been sitting in dry storage.Building a stroker engine?? I got the core..Only $150.I will not ship.Needs to be pick up in NEW HAMPSHIRE.Calls only 603 209 1678.I do not answer emails ever..So call
Edited by littleredcoffin (01/17/19 11:57 AM)
#2608311 - 01/17/19 07:59 PM For Sale: Mopar Small Block Fuel Pump [Re: moparts]
vinnyd76 Offline
Loc: Macomb, MI
For sale is a brand new Mopar small block mechanical fuel pump. The part number is P4007040.
Price: $50 obo
#2608430 - 01/18/19 12:38 AM Re: For Sale - Small Block Engine - 1st Quarter [Re: moparts]
humpty Offline
Loc: Minnesota, USA
*** Sold ***
408ci stock 360 block converted to 4 bolt mains, main studs, align honed, square decked and torque plate honed. Balanced forged rotating assembly with Probe pistons and Ohio Crankshaft crank and rods. Total Seal gapless top ring, low tension oil ring pack. Ported iron race W2's with ARP head studs, Cometic head gaskets, 2.100 stainless intake and 1.60 valves, titanium retainers, Harland Sharp full roller rockers, ported Indy 360-3R Intake, blended 4150 to 4500 adapter. 11.8:1 compression. Comp Cams 269/276 duration 697/699 lift solid roller, Kevco modified stock pan. Hi volume Milidon oil pump. Superformance gaskets. This is a quality build with quality parts and has 100 runs since refresh. Over $11k invested in the build. There is $1,100 in block machining alone. The combo made 605hp/540tq on a conservative dyno and went 6.30's at 109 mph in the 1/8mi. and a best of 10.18 @ 132 in the 1/4 mi in a 3150lb Duster. I'm going R3W9 so this one has to go. TTI A Body headers included. $6,500 + shipping. ThumperCarbs 1050 Dominator available for an additonal $1,000. PayPal preferred. PM me here if interested.
Edited by humpty (01/19/19 04:23 PM)
72 Duster - 408ci W2, 10.18@131, 6.31@110.
https://m.youtube.com/watch?v=Q4P51j38-MI
#2608699 - 01/18/19 03:25 PM Re: For Sale - Small Block Engine - 1st Quarter [Re: humpty]
moparjohn Offline
Loc: N.W. INDIANA
I have for sale a single snorkel air cleaner. The price is $125.00 plus shipping. If you interested contact me at: moparjohn@frontier.com with your zip.
Thanks!
Edited by moparjohn (01/24/19 08:41 PM)
#2608746 - 01/18/19 05:21 PM Re: For Sale - Small Block Engine - 1st Quarter [Re: moparjohn]
moparjohn Offline
Loc: N.W. INDIANA
I have for sale some original factory spark plug wires. These would be great for that survivor car! Here is a list of what's in the picture:
Front row left is a 1st quarter 1967 wire with a straight plug boot and is 31" long priced at $25.00.
Front row right is a 1st quarter 1967 wire with no boots 38" long priced at $20.00.
Middle row left is a 1st quarter 1967 wire with a straight plug boot and distributor cap boot 24" long priced at $25.00.
Middle row right is a 1st quarter 1967 wire with no boots 31" long and priced at $20.00.
Back row center is a 3rd quarter 1965 wire with a straight plug boot and factory retainer priced at $25.00.
You can buy them all for $100.00. Prices do not include shipping.
Will trade for original/NOS 1st quarter 1969 wire 38" long or an
original/NOS 3rd/4th quarter 1969 wire 30" long.
If your interested contact me at: moparjohn@frontier.com with your zip.
Thanks!
#2609285 - 01/20/19 10:05 AM Re: For Sale - Small Block Engine - 1st Quarter [Re: moparjohn]
Joesixpack Offline
NOS 273-340 1658535 DUAL POINT IGNITION ROTOR$25
#2609286 - 01/20/19 10:07 AM Re: For Sale - Small Block Engine - 1st Quarter [Re: Joesixpack]
Joesixpack Offline
273-340 dual point tune up kit
MADE IN THE USA parts$35 mailed
#2611033 - 01/23/19 11:10 AM 340/360 heads unused since rebuild 3671587 [Re: moparts]
71autoxr Offline
Loc: AZ - The "dry heat" state
SOLD Thanks MOPARTS
Edited by 71autoxr (02/09/19 06:28 PM)
68 AMX mopars red headed stepchild
69 Dart GT Convertible 340 4 speed
71 Challenger - looks like the avatar!
#2611569 - 01/24/19 11:48 AM misc small block parts. [Re: moparts]
all spooled up Offline
Loc: ohio
nos mopar performance new w5 intake gaskets .035 thick 15.00$
318 engine mount brackets 67-72 type powder coated black 30.00
small block new installed never fired never ran 14 mopar per valve springs p/n p3614542 35.00
3 sets of comp cams crane cams small block valve spring retainers all like new cond 35.00 for all
will sell all parts for 80.00 pm or email for pics 347cutty@gmail.com
Edited by all spooled up (01/24/19 11:58 AM)
#2611728 - 01/24/19 03:46 PM Small Block Spool Mount Replacement Kit [Re: moparts]
392Hemi Offline
Loc: Michigan
Item #: SCH73PLA
Fits: 1973 & Up Poly Spool 340/360 Replacement Kit
Original V8 Spool Mount Replacements available for '73 & up A,B,F,M,J-Body 273, 318, 340 and 360 engines. Kit includes powder-coated brackets, polyurethane spool inserts and mounting hardware
$125 obo have to go
74 Dart Sport
Recreation to Gen3 Power!!
ET's coming soon
#2611941 - 01/25/19 01:55 AM Re: For Sale - Small Block Engine - 1st Quarter [Re: moparts]
nitroram33 Offline
Loc: Robbinsville, NC
Forged 365ci Small Block Mopar/Chrysler/Dodge Longblock - $3900 - Robbinsville, NC
So, after much thought and deliberation, I've decided to go a different direction (Gen 3 Hemi) with my Dakota R/T and I'm selling off all the Magnum stuff I've been hoarding. Up for sale here is a forged 365ci Small Block Mopar/Chrysler/Dodge (whichever you want to call it). The engine is fresh and has never been fired, but has been bagged up in a crate under the work bench in my shop for a few years. Specs are below:
Kammer and Kammer in Dayton, Ohio balanced the rotating assembly (internally balanced) and did the machine work on the block, heads were done elsewhere.
Compression ratio of the setup how it sits right now: 9.525:1
Stock 360 Magnum block, .030 over. NOT filled. (Machine work done by Kammer and Kammer.)
Forged Eagle stock stroke 3.580" crank
Forged SCAT I-beam 6.123" rods
Forged Probe .030 over pistons -14.5 cc (Supposedly the same ones Duner is running in his turbo truck)
Total Seal CS3690-35 rings
Clevite bearings
Bullet cam custom grind by Ryan J @ Shady Dell Speed Shop 232/244 @ .050" 114 LSA .576"/.576" (Designed with him knowing the head flow numbers and knowing it will see boost)
Mopar Performance Lifters
Custom Smith Bro Push rods
Felpro 1008 head gaskets
Ported 2.02 Mopar Performance "R/T" heads (Combustion chambers on the heads are 60.6 cc's)
Comp Cam 1.6 roller rockers
ARP Head bolts
ARP main bolts
Mellings stock flow oil pump and new pick up
Modified oil pan with oil drain
New timing chain set
Asking $3,900 or best offer.
Edited by tboomer (01/25/19 05:48 AM)
Edit Reason: 4 pic limit
RaceMagnum.com A home for late model EFI Dodge trucks and a sense of humor.
#2612183 - 01/25/19 03:39 PM Fluidampr SB Mopar Harmonic Balancer [Re: moparts]
humpty Offline
Loc: Minnesota, USA
*** Sold ***
New - never been installed. It was sitting on the shelf so there are a few scuffs on it. Part number - 720301. Fits 318/340/360.
Find the specs here: https://fluidampr.com/chrysler/#1
$413 at summit: https://www.summitracing.com/search?keyword=fluidampr%20720301
I bought this for a project but don't need it.
$300 shipped.
Edited by humpty (01/27/19 10:53 PM)
#2615435 - 01/31/19 11:29 PM NOS 3614375 Crankshaft Single Groove Pulley for 70s 340... [Re: ragtop]
xs29j8 Offline
Loc: Fort Worth, Texas
NOS single groove pulley for 1970 340 Mopar...
Price is $135 which includes shipping to mainland US addresses ...
Allen Vasut
PM me to ask questions
#2615757 - 02/01/19 07:53 PM Re: For Sale - Small Block Engine - 1st Quarter [Re: schmitty]
peterpetrolhead Offline
Loc: melbourne australia
Please contact the seller via pm or e-mail. This is not a discussion forum.
Edited by tboomer (02/02/19 07:04 AM)
Edit Reason: not a discussion board
25,741 Registered Members
192,936 Topics
WIW: Stock LA Motor Connecting Rods
by vinnyd76
Today at 12:12 PM
What would win, road grader vrs MGB?
by GODSCOUNTRY340
Today at 12:03 PM
EMISSIONS CODE P0440
by moparsquid
Today at 11:30 AM
Brake calipers
by scottyb1955
Today at 11:17 AM
