Re: How far have you run a turned down crank
[Re: scottb]
#2608954
01/19/19 01:23 PM
01/19/19 01:23 PM
Posts: 1,237 North Central, Indiana
Roughbird72
Many stock 440 cranks have had .125 taken off the mains to install in 400 blocks and taken a beating. I'm not sure another .010-.020 would make that big of a difference from where you're at now.
72 Plymouth Roadrunner 11.08@123.25
[Re: scottb]
#2608968
01/19/19 01:49 PM
01/19/19 01:49 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Turn it down to whatever you can get bearings for.
[Re: TRENDZ]
#2609047
01/19/19 05:17 PM
01/19/19 05:17 PM
Posts: 2,578 sweden
1Fast340
sweden
Turn it down to whatever you can get bearings for. This!
[Re: Roughbird72]
#2609051
01/19/19 05:26 PM
01/19/19 05:26 PM
Posts: 22,695 Bitopia
jcc
Bitopia
Many stock 440 cranks have had .125 taken off the mains to install in 400 blocks and taken a beating. I'm not sure another .010-.020 would make that big of a difference from where you're at now. That makes sense to me. Wonder why for decades a .010-.030 turned crank was so frowned on.
[Re: jcc]
#2609057
01/19/19 05:36 PM
01/19/19 05:36 PM
Posts: 4,457 Washington
madscientist
Washington
Many stock 440 cranks have had .125 taken off the mains to install in 400 blocks and taken a beating. I'm not sure another .010-.020 would make that big of a difference from where you're at now. That makes sense to me. Wonder why for decades a .010-.030 turned crank was so frowned on. Because back in the day, like before my time most likely the mid 70's at the latest undersized bearings all had the same shell thickness and the overlay was made thicker to get the next undersize. As the overlay became thicker (I've heard it was anything more than .020 under) it would start to migrate and then flake off. It became worse as the undersize was more and the HP/RPM went up. Now, they all use different shell thicknesses and they use the same thin overlay. Grind it down to small block Chevy large journal if you want. Makes bearing choice much easier. I did that on every Chrysler crank I did. The customer would [censored] like crazy until rebuild time came. No one wanted to grind a new crank, but I did it anyway.
[Re: scottb]
#2609073
01/19/19 06:24 PM
01/19/19 06:24 PM
Posts: 11,524 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I cut a 360 iron crank to 340 size to get some cheap cubic inches. Worked fine. Broke the motor, but it wasn't the cranks fault. Offset grinding to get a smaller pin + more stroke is common. My level of comfort would depend on the material.
[Re: scottb]
#2609076
01/19/19 06:28 PM
01/19/19 06:28 PM
Posts: 1,557 New Smyrna Beach FL
scottb
New Smyrna Beach FL
It’s a 4340 crank it’s a molnar 3.79
[Re: scottb]
#2609159
01/19/19 11:10 PM
01/19/19 11:10 PM
Posts: 4,206 New York
polyspheric
New York
No data w/r/t MoPar cranks, but factors on regrinding other makes: 1. the drilled oil transfer hole is slanted in the journal, and is uncovered with a big undersize - lost OP 2. the grinding didn't use the correct cheek radius, too large (not enough metal removed) will bind the shell 3. crank stiffness is reduced by both the extra stroke and smaller journal, typically small enough not to matter. Read more in my article: http://victorylibrary.com/mopar/journal-c.htmI wrote an .xls spreadsheet to compare the actual (intersecting lenses) overlap area vs. nominal (diameters compared) area, e-mail for a free copy.
Boffin Emeritus
[Re: Dragula]
#2609284
01/20/19 01:03 PM
01/20/19 01:03 PM
Roughbird72
If you can get bearings for it, fine...Never seen -.03 though. I believe King makes a .030 under main bearing.
[Re: 500ciDuster]
#2609364
01/20/19 03:48 PM
01/20/19 03:48 PM
Posts: 43,116 Bend,OR USA
Cab_Burge
Was thinking years ago they made .060 under for rods & mains Maybe for some other brands and industrial applications I can't remember the name of a company in SO CA that specializes in old car parts but I seem to remember them offering under size bearings for some old motors in .040 and maybe smaller I have seen .040 listed years ago for early Poly 318 motors and the same for the 273,318 and 340 LA motors
