360 swap #2608944
01/19/19 12:49 PM
01/19/19 12:49 PM
michigan
rscottick Offline OP
michigan
may be silly but will my motor mounts from my old 340 work with a 360 going into my 70 duster?
Re: 360 swap [Re: rscottick] #2608951
01/19/19 01:15 PM
01/19/19 01:15 PM
Andrewh Offline
Andrewh  Offline
pretty sure it is 318 and 340 are the same.
360 is different on only one.
and you can use spacers to make up for the difference if you want, or get the correct one.
Re: 360 swap [Re: rscottick] #2608977
01/19/19 02:09 PM
01/19/19 02:09 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
The passenger side mount is the same for all small blocks. 360 mount ears on the driver's side are spaced further apart. As Andrew said you can simply space it out with a pack of washers if you wanted to reuse your existing mounts.
Re: 360 swap [Re: Andrewh] #2608998
01/19/19 03:02 PM
01/19/19 03:02 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
273/318 same both sides
340/360 same both sides.
273/318 moutn wider than 340/360 mount on one side.
So yes, the 340 mounts will just fit the 360 no problem.
Don't be the exception.
Re: 360 swap [Re: Supercuda] #2609009
01/19/19 03:37 PM
01/19/19 03:37 PM
michigan
michigan
Thanks for the info!!!!!!!!!!!!!!
