E-body instrument cluster removal/install #2605421
01/12/19 03:14 PM
01/12/19 03:14 PM
BLACKHEMIRR Offline OP
Is the dash pad supposed to be removed in order to remove and re-install the gauge cluster on a 71 Cuda with the rally dash? I removed it with out taking the dash pad off, but I think the emergency brake light tube broke while I was trying to figure out how the woodgrain bezel came out. I think it would be a lot easier with the dash pad off, but is it necessary? I removed the radio, ash tray, lower dash pads, and lowered the column. Thanks in advance
Re: E-body instrument cluster removal/install [Re: BLACKHEMIRR] #2605508
01/12/19 05:49 PM
01/12/19 05:49 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
If its just the cluster, you did fine
Re: E-body instrument cluster removal/install [Re: BLACKHEMIRR] #2608861
01/19/19 01:46 AM
01/19/19 01:46 AM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
No need to remove dash pad, etc...u did fine.
