Re: BB bellt drive, who makes them besides Jesel?
[Re: Cab_Burge]
#2609893
01/21/19 03:11 PM
01/21/19 03:11 PM
Posts: 19,360 Las Vegas
Al_Alguire
Las Vegas
The Aussie Belt drives ALL have idlers. Jesel is just the raised cam stuff
[Re: Al_Alguire]
#2610003
01/21/19 06:48 PM
01/21/19 06:48 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
I ran an old Australian Muscle Parts belt drive. I felt like I was the R&D guy for him. I finally quit emailing and just made it work. Would like to see his come back just for some competition. As for the idler it is on ALL the raised cam BB Mopar Jesel. If you are patient they can be located from time to time, I will warn you if you buy a used one and it needs a belt or seals may as well buy new. They are quite proud of their stuff I have one on my small block........I bought it used , then started buying parts. Yeah......if I do another motor with one , it will be new in box , from the manufacturer or distributor. The set up I bought had the plate for a low deck small block , so I bought the backing plate too. I didn't save a more than maybe 150.00 , but I got a solid understanding of how they want to go together and work. LOL
Re: BB bellt drive, who makes them besides Jesel?Update
[Re: Cab_Burge]
#2610893
01/23/19 05:27 AM
01/23/19 05:27 AM
Posts: 43,123 Bend,OR USA
Cab_Burge
I decided to buy a new Mildon gear drive for this motor, it should be here by Friday, I hope I've installed and race them as well as KB and Donovan gear drives, this current motor will have a little over 850 Lbs. over the nose and around 300 Lbs. seat pressure Thanks to all of you for your help
[Re: Cab_Burge]
#2610900
01/23/19 07:02 AM
01/23/19 07:02 AM
Posts: 4,457 Washington
madscientist
Washington
I decided to buy a new Mildon gear drive for this motor, it should be here by Friday, I hope I've installed and race them as well as KB and Donovan gear drives, this current motor will have a little over 850 Lbs. over the nose and around 300 Lbs. seat pressure Thanks to all of you for your help Not a single thing wrong with that gear drive.
[Re: rebel]
#2622953
02/18/19 04:05 PM
02/18/19 04:05 PM
Cab_Burge
was talking to Mike from 'Strayln Muscle parts today, said he is almost ready to release the new version of his belt driove for BBM's. we had a good talk & the new unit is going to have big improvements over the original. He's hoping the production will start in the next few months & hopefully priced better than the Jesel. He tells me Todd will probably be one of his dealers. watch this space Thanks for the heads up
[Re: rebel]
#2623110
02/18/19 11:17 PM
02/18/19 11:17 PM
Posts: 1,098 Massillon, Ohio
cudatom
Massillon, Ohio
He send me a pic of his new Ford unit, said his new Mopar one will look similar. Have never ran a belt drive but will be on my next engine. With that said is there a benefit with the idler. I know many of you have lots of experience with this stuff so I figured I will get the straight scoop.
Ok
[Re: cudatom]
#2623319
02/19/19 02:37 PM
02/19/19 02:37 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
He send me a pic of his new Ford unit, said his new Mopar one will look similar. Have never ran a belt drive but will be on my next engine. With that said is there a benefit with the idler. I know many of you have lots of experience with this stuff so I figured I will get the straight scoop. The only reason to run the Idler from those pics is because there is not a belt that is an exact fit, the pulley takes up the slack. This single idler method also can change timing, that is why the cam pulley is adjustable, it compensates for any tightening or loosening of the belt. Its not a bad design, it has been proven on tens of thousands of accurate 3 axis milling machines to drive the spindle. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: wyldebill]
#2623597
02/20/19 04:34 AM
02/20/19 04:34 AM
Posts: 30,994 Oregon
AndyF
Going to be completely honest, what are the advantages of the belt drive? Will you really see the horsepower per dollar? There are a lot of advantages for a serious race engine. Not so sure that power is one of them.
[Re: AndyF]
#2623706
02/20/19 02:37 PM
02/20/19 02:37 PM
Posts: 20,158 PA.
pittsburghracer
"Little"John
"Little"John
PA.
100’s if not 1000’s of 8 second passes with my Mopar big blocks running roller timing chains with zero issues. Some get caught up in tricks, some don’t. Spend YOUR money wisely.
[Re: wyldebill]
#2623709
02/20/19 02:41 PM
02/20/19 02:41 PM
Cab_Burge
I building a rather serious street car engine. I've looked at them, just hard to justify the expense. Especially since no one can give me any proven reasons. I've used a Jesel belt drive on one motor so far, I wasn't really impressed with it hence the choice on the gear drive for this current street motor. To bad Cloyes has now goofed up all the better BB Mopar timing sets Setting up a single idler gear drive can be a pain but it way better than breaking a timing chain in two or three years of street use or a belt
