Wiring question for the experts on 1999 Ram
#2606951
01/15/19 02:59 PM
01/15/19 02:59 PM
Posts: 425 Eastern Ontario
shaker340
Eastern Ontario
I transplanted 1999 Ram 1500 5.2L and 46RE along with the engine harness & PCM to a 1940 Chrysler Royal. I did not take any of the emissions stuff.
I merged the 99 engine harness into a 96 Dakota 3.9 Harness to get all the fuse box, lights etc. This was a lot of work!!!
So, the engine starts if we dump fuel manually into the throttle body and runs as we spray fuel into TB.
The ASD relay is not seeing power on pin 85, and I suspect same for the fuel relay. And so no fuel signal to injectors and no fuel pump.
I think this would be due to PCM not seeing the Leak detection pump and other emissions stuff?? or????
Maybe I need a PCM for hot rod application?
Thanks in advance, Mike
2008 Challenger SRT8 1940 Chrysler Royal coupe
Re: Wiring question for the experts on 1999 Ram
[Re: BleedDodge]
#2607388
01/16/19 11:02 AM
01/16/19 11:02 AM
shaker340
Eastern Ontario
I merged the two harness because the Dakota engine connectors were not the same as the 99, and routed differently than the V8. Also the Distribution box is very large on a 99 Ram, where the Dakota was half the size and contained the necessary relays for ASD, Fuel and Transmission.
Mike
[Re: poorboy]
#2607389
01/16/19 11:07 AM
01/16/19 11:07 AM
shaker340
Eastern Ontario
Poorboy, I will look for those wires you describe, they are near the Distribution Box in the engine bay and not the fuse box under dash correct?
Mike
[Re: shaker340]
#2607899
01/17/19 02:07 AM
01/17/19 02:07 AM
Posts: 969 manitoba canada
BleedDodge
manitoba canada
Mike Right, the distribution boxes are different between those few years, that’s why I wasn’t able to use the engine harness from my wrecked 99 ram in my 97 ram. I guess I just don’t understand why you’re having to combine harnesses in the first place. Stuff is going into a 1940 vehicle right so why not just use the 99 harness completely. Maybe I just need to read your original post a few more times to get it, haha.
[Re: BleedDodge]
#2608002
01/17/19 12:09 PM
01/17/19 12:09 PM
shaker340
Eastern Ontario
BleedDodge, I could have pulled the complete harness from the 99 Truck, but it has so much other stuff I didn't want. The Dakota is a much simpler wire system. I wish I had waited until a V8 Dakota was for sale, and used all of that harness. Not many 96 Dakota in these parts anymore.
Mike
[Re: shaker340]
#2609813
01/21/19 12:20 PM
01/21/19 12:20 PM
shaker340
Eastern Ontario
I think I know whats causing the no fire at the injectors. The 99 Ram had anti-theft security via a chip in the key. And I bet the computer is looking for that and not seeing it. So I need a computer that runs the 5.2 and the 42RE trans that does not have anti-theft function.
Any suggestions what vehicles have OBD2 without the security?
Mike
[Re: poorboy]
#2610266
01/22/19 02:55 AM
01/22/19 02:55 AM
Posts: 954 garnett kansas
rhad
garnett kansas
i have a 02 grand cherokee that had a security key problem,i sent the computer to a guy in ohio that deleted it for me $140 found him on ebay
my ladder of success is missing some rungs
[Re: rhad]
#2610369
01/22/19 12:47 PM
01/22/19 12:47 PM
shaker340
Eastern Ontario
More info, the 99 Ram does not have a chip in the keys. But it did have VTSS system programmed in the PCM, and I did not take the Central Timer Module from the 99 Ram. The CTM talks to the PCM by the +CCD and -CCD so this must be whats causing the no start.
I found a yard that has a few 96 thru 2001 Rams and will grab the PCM and CTM from one of them. I would really like to find a 96 5.2L Dakota PCM it has none of the security stuff on it.
We will get there....the hard way.
Mike
[Re: shaker340]
#2613428
01/28/19 11:21 AM
01/28/19 11:21 AM
shaker340
Eastern Ontario
Major success over the weekend. We found a PCM from a 96 Ram and 97 Ram tried both and the motor fired up and idled. So the issue was the Anti theft system on my 99 PCM.
I attached my chart between Ram and Dakota showing what wires needed to match between the Ram engine harness and the Dakota harness. This was a lot of work looking at the two service manual schematics. You can see the wires from the Ram eng harness just below the Dakota bulkhead connector and a few wires soldered going into the Dakota harness.
Mike
[Re: poorboy]
#2615017
01/31/19 01:17 PM
01/31/19 01:17 PM
shaker340
Eastern Ontario
Gene, many thanks for the compliments. You were a major inspiration and resource as we travelled down this path.
Wires wrapped in harness tape, convolute tubing to follow once we get the front end on.
Mike
