2016 engine and 545rfe #2606625
01/14/19 09:10 PM
01/14/19 09:10 PM
norway
aufles.mopar Offline OP
norway
Hi
I'm mounting together an 2016 5.7L hemi from a ram pickup and a 2010 545rfe transmission. should it be a steel plate between engine and transmission as on the older 05mod engines.
1971 cuda and 1934 plymouth hotrod
Re: 2016 engine and 545rfe [Re: aufles.mopar] #2607717
01/16/19 08:49 PM
01/16/19 08:49 PM
norway
norway
nobody know if it should be a steel plate beween engine and transmission
Re: 2016 engine and 545rfe [Re: aufles.mopar] #2609501
01/20/19 08:11 PM
01/20/19 08:11 PM
norway
norway
Re: 2016 engine and 545rfe [Re: aufles.mopar] #2609627
01/20/19 11:14 PM
01/20/19 11:14 PM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
Bouchillion Performance shows on for the GenIII & 545rfe,they don't specify year.I would call them to verify but I'd bet it is needed on the later block as well.
