Radiator cooling fins break down into 'dust'...
#2606547
01/14/19 06:16 PM
01/14/19 06:16 PM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
This is the second radiator in a number of years that seems to be disintegrating from the outside. The thin cooling fins between the actual ribs are disintegrating, and turning into a copper-dust/powder. Car is a daily driven 1973 Dodge Dart. It's clear some kind of galvanic corrosion is happening here but I'm wondering why because it can't be an 'isolated issue'? I try to save the radiator and apply a coat of satin black paint on it occassionally, but ofcourse this might slow it down but doesn't seem to stop it.
Re: Radiator cooling fins break down into 'dust'...
[Re: BigBlockMopar]
#2606553
01/14/19 06:28 PM
01/14/19 06:28 PM
RapidRobert
Out on a limb here but could it be electroyalisis (sp)? Someone said once about with your meter on low volt scale, one probe in the coolant & the other touching the radiator metal & over a certain # of tenths of a volt being generated that there is some galvanic action takeing place (like a battery that is causing corrosion/rusting).
[Re: BigBlockMopar]
#2606563
01/14/19 06:52 PM
01/14/19 06:52 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Do you live by a nuke plant or a military shoot to kill trespass base? Does your pee glow?
[Re: BigBlockMopar]
#2606568
01/14/19 06:59 PM
01/14/19 06:59 PM
BigBlockMopar
The Netherlands
Not more than usual... I do wonder if the occassional road salt will speed-up the process at hand here. We've had a very mild winter here uptill now with only one-or-two road salt applications. As for the electrolysis, I understand, but wouldn't that be happening on the inside of the cooling system where the coolant actually touches the copper (and iron and aluminium). I could try and stick a voltgauge on various places in/on the cooling system to find voltage-differences. I've also been thinking of insulating the radiator from the frame it's mounted to. But then again, millions of cars have been made this way. If there was a problem it would have become apparent very quickly I think.
[Re: BigBlockMopar]
#2606570
01/14/19 07:01 PM
01/14/19 07:01 PM
jcc
Bitopia
Maybe think about a sacrificial anode (zinc?) solution?
[Re: BigBlockMopar]
#2606588
01/14/19 07:43 PM
01/14/19 07:43 PM
jcc
Bitopia
My thinking is the current is now flowing to an unknown cathode agent outside the rad, thru the uncoated inner metal, an interior immersed anode would reverse that current flow direction, or at least reduce it.
[Re: jcc]
#2606773
01/15/19 02:42 AM
01/15/19 02:42 AM
Posts: 954 garnett kansas
rhad
garnett kansas
my opinion after 37 years of radiator repair,its salt!!,do you live near the ocean by chance??
my ladder of success is missing some rungs
[Re: BigBlockMopar]
#2606782
01/15/19 03:47 AM
01/15/19 03:47 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
He lives in the Netherlands, you know where the little Dutch boy put his finger in the dyke to keep the ocean from flooding the countryside. Yeah, he lives by the ocean.
[Re: rhad]
#2607016
01/15/19 05:00 PM
01/15/19 05:00 PM
Posts: 3,042 N.W. Florida
Fat_Mike
N.W. Florida
my opinion after 37 years of radiator repair,its salt!!,do you live near the ocean by chance?? I too thought of salt or other road de-icing materials. But I assume the problem would be widespread in the OP's region, and therefore he would know the cause. I could be wrong...
[Re: BigBlockMopar]
#2607516
01/16/19 03:07 PM
01/16/19 03:07 PM
Posts: 3,334 home of the Buckeyes
Butterscotch71
Lost Title
Lost Title
I have a radiator doing that in a car that came from Nevada with absolutely no rust underneath (and I assume no exposure to salt and very little to rain).
addict:to devote or surrender (oneself) to something habitually or obsessively ....hmmmm
[Re: Butterscotch71]
#2607520
01/16/19 03:13 PM
01/16/19 03:13 PM
jcc
Bitopia
I have a radiator doing that in a car that came from Nevada with absolutely no rust underneath (and I assume no exposure to salt and very little to rain). I wonder in your case if it could be a caustic agent (alkali) at work, lime dust, etc
[Re: BigBlockMopar]
#2608762
01/18/19 09:11 PM
01/18/19 09:11 PM
BigBlockMopar
The Netherlands
Freezing nighttime temps have arrived here in my country and the roads are already turning white, from the salt! I took some pre-emptive measurements and sprayed a layer of zinc-primer on the front of the radiator. Hope it stays together this winter... I sometimes think the roads are slippier because of all the salt they dump on them than from some possible frost that might appear on the surface...
[Re: BigBlockMopar]
#2609101
01/19/19 07:44 PM
01/19/19 07:44 PM
BigBlockMopar
The Netherlands
I daily drive the car year round. Snow or shine! It's my only means of transportation, besides the 'older' cars I have, which function as backups if the Dart needs to spend time in the garage. We don't really have much winter snow overhere usually, at least not in my part of the country. There is however some snow forecast for tuesday. This was back in 2012, which was a colder winter for us. Sure had some fun in that white mess...
