A body steering column shaft, all the same length? #2606304
01/14/19 03:22 AM
01/14/19 03:22 AM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
Are the steering column shafts the same length between a power and manual, if the sheer pin is removed?
I ask because the threads on my manual floor shift column were stripped and I have a nice power steering column that I could use for parts.
I know on 69 B bodies that the steering shaft has multiple positions for the plastic sheer pin to go into once its been removed (or melted!). Just curious before I take the column apart.
Re: A body steering column shaft, all the same length? [Re: NV69B7RR] #2606317
01/14/19 05:58 AM
01/14/19 05:58 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
There is a 1-2" difference between the two because of the power box being longer.
