two step #2604026
01/09/19 06:34 PM
01/09/19 06:34 PM
Spring Valley ,Ca.
moparsquid Offline OP
Spring Valley ,Ca.
hello I'm planning on instaleing a msd 2 step module I know 1 end goes in the msd one is power and the other I think is the trigger where is the best place to put it
Re: two step [Re: moparsquid] #2604193
01/10/19 12:06 AM
01/10/19 12:06 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I have hooked them up to the brake light switch, a pressure switch in the brake line or the trans brake switch. All depends on what you want to accomplish.
Re: two step [Re: moparsquid] #2604778
01/11/19 03:12 AM
01/11/19 03:12 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Just as slant said above, it depends on the surrounding hardware. If it’s a footbrake car, the best option is to install a pressure actuated switch into the brake system and run it off that. The easiest is to wire it right into the brake light switch. This is how my car is done and it has worked great and reliably for me for years now.
Re: two step [Re: slantzilla] #2604837
01/11/19 12:02 PM
01/11/19 12:02 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Many a Ford has caught fire when a brake pressure switch started leaking. Seen it happen to a friends F150 after it had been parked for 3 hours. Lucky for him I was having a smoke and saw the start of it, I grabbed a fire extinguisher and put it out. He left his doors unlocked.
I would forgo a two step rev limiter before I used a brake pressure switch, especially since you already have a switch on the pedal.
Don't be the exception.
Re: two step [Re: moparsquid] #2605012
01/11/19 04:55 PM
01/11/19 04:55 PM
Chicago
PurpleBeeper Offline
Chicago
I REALLY like slantzilla's idea of wiring into the brake light switch.
If you have a 4-speed car, then maybe a push button the shifter? I have a 2-step which isn't installed yet and plan to wire it together with a line lock to a switch on the shifter (since I need both feet to launch & I have 3 pedals)
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: two step [Re: PurpleBeeper] #2605029
01/11/19 05:40 PM
01/11/19 05:40 PM
Washington
madscientist Offline
Washington
If you have a clutch the switch goes on the clutch pedal, not on the line lock. I don't care how good you are, you will never get the button off at the correct time twice in a row.
Set it up on the pedal and make sure that as soon as you move your foot the switch clicks. That way, your not loading the engine while the two step is on. That's a promised parts breaker.
Re: two step [Re: madscientist] #2605184
01/11/19 11:18 PM
01/11/19 11:18 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I have two switches in series,one mounted to my clutch pedal stop on the floor and the other on the transmission at the first gear lever. That way the 2 step circuit is only active when the clutch pedal is on the floor and the tranny is in first gear.
Gus beer
64 Plymouth Savoy
Dana 60
Re: two step [Re: moparsquid] #2605879
01/13/19 02:09 PM
01/13/19 02:09 PM
Spring Valley ,Ca.
Spring Valley ,Ca.
I was going to use the factory brake light switch on the peddle or use a micro switch to activate it as it is a foot brake car, thanks to all responders for suggestions I've never have never used one before thanks
