#2605072 - 01/11/19 03:54 PM Starting w stock '68 RoadRunner - First steps? what shocks?
67SATisfaction Offline
Loc: Albany, NY
Hey guys, thanks for looking.. this has prolly been asked a million times, right?
My brother loved track racing his bone stock '68 RR last year and is coming back this year for more... I've got a European sports car I track race, so I'm all set.. but I'm helping guide him in his first basic steps to improve..
This is a 2.1mile road course with 18 turns and 450ft elevation change. Lots of braking and turning. I don't know his budget, but I know he has limited time to install the improvements before track day (his RR is in storage til two days before track day.."What Could Possibly Go Wrong?".. rolleyes ).
Please share your thoughts on the following "low hanging fruit" to improve his RR, I think it's basic enough to be pretty solid, but running it by you Mopar guys in case I'm missing something...
Not looking for "Full on" racecar, just some good incremental improvements that won't degrade street-ability too much.
1. Tires. Currently 14" street radials.
- Buy a new set of 15" steel rims, he has decided on a set of grippier Cooper tires.
2. Brakes. Currently stock drums, manual.
- He'd like to go with front discs, but with limited time to install and troubleshoot, I suggested a shop that offers high-perf linings for existing drum shoes. We can swap them in quickly. It'll put more heat to the drums, but willing to try it out.... See how it goes.
3. Suspension. Stock torsion and new OEM rear leaf springs.
- So far, just a slightly stiffer front sway to reduce oversteer. He's found a front sway he likes from Hotchkis (I like the FirmFeel front & rears on my '65. We each have our druthers).
4. Shocks. No idea what he has now, but definitely plain street spec.
- I'm going to suggest he go with stiffer shocks, but I have no experience sourcing or spec'ing anything (I upgraded my '65 to Monroe GasMatics fronts and I forget what I put on the back, but they were yellow Monroes, a little stiffer). Any suggestions? I found Koni has a search function that lists some shocks for the RR.
5. Seating. Stock bench seat.
- We get thrown around a lot. I'm not sure what will help without changing out the bench. Are there belts that will hold us in better, that bolt in?
Am I steering him OK? Anything else that might be easy, quick and reliable?
Thank you,
- Art
Edited by 67SATisfaction (01/11/19 04:24 PM)
1965 Satellite hardtop 361/2bbl, auto, pegleg 2.76
1967 Satellite convert 383/4bbl, auto, pegleg 3.23
1975 Maserati Bora, 4.9L DOHC hemi V8, 5-spd ZF
1982 Alfa Romeo GTV6, 2.5L SOHC hemi V6, 5-spd transaxle
1994 Alfa Romeo 164LS, 3.0L SOHC 24v hemi V6, 4spd auto ZF
2007 Aston Martin DB9, 6.0L DOHC V12, 6spd full manual transaxle
#2605253 - 01/11/19 10:25 PM Re: Starting w stock '68 RoadRunner - First steps? what shocks? [Re: 67SATisfaction]
Loc: Albany, NY
OK, a number of you have looked at this post without comment, so I gather we're on the right track (ha ha, get it?).. and I'm not being sarcastic when I saying Thank You for looking at this.
Cheers,
- Art
#2605292 - 01/12/19 01:52 AM Re: Starting w stock '68 RoadRunner - First steps? what shocks? [Re: 67SATisfaction]
Skeptic Offline
Loc: The Pale Blue Dot
Cheers,
- Art
Honestly it reads like a joke post. There isn't a single point that indicates an effort to make the car even marginally safe on a track. shruggy Disk brakes, big ones, all around- Talk to Cass, otherwise known as Doctor Diff He sells cost effective brake kits for our old cars and is an upright guy.
_When a 3000 lb Toyota Corolla comes with 11.5" front disks and 10.5" rear disks can you really think that a 4000 lb B body is gonna stop from speed with drums. My 68 barracuda had 10" drums and the brakes were garbage. Not worn out, not mis-adjusted, just not up to the task even in commuter traffic.
_ I'd suggest Hotchkis or Firm Feel for sway bars/springs and shocks. Hotchkis has a 4 door B body they beat on auto-X courses and runs circles around newer sports cars, the Firm Feel guys have years of racing experience. You won't go wrong talking to them and their products work.
_ You can get a limited number of 15" tires that will work on a track, if you must. You are really limiting the brake sizes for stopping a big car, I'd get 17" or 18" wheels and tires. There are retro looking wheels in those sizes if the look isn't to your liking. twocents
#2605343 - 01/12/19 09:42 AM Re: Starting w stock '68 RoadRunner - First steps? what shocks? [Re: 67SATisfaction]
Mattax Offline
Loc: Phila. Pa.
#1. Change the brake fluid. Valvoline's 'synthetic' is pretty good stuff.
#2 Check everything else over. Brake shoes, oil, tires, oil, etc.
#3 Have a good time.
That's doable. Not sure how much difference in grip there will be. If it shortens the sidewall, gets more tread width, and maintains the load rating it should be a plus.
Package may weigh more. You should note that Scott Harvey recommended doubling up on the spiders of steel rims, at least for rally. There's a classic photo of the Chrysler France Hemi 'cuda with a broken ralley rim. A circle track rim like Basset makes might be stronger and lighter.
An aluminum rim with lots of cross sectional strength is worth looking into. ie styles torque thrust, mini-light, mag star, or 'ansen' slots.
Since he owns the 14s, maybe the new set of tires is dedicated to track rather try to make them dual purpose. wink
Bring some method of checking drum temps. See how much wear is on the ones on there from last outing, and if visible, the edge code. Rochester Brake and Clutch is worth talking with about linings and they can arc them too.
Tricky part is the car is inbetween street and track. Linings for racing with front drums will generally not be great for street. With the street tires, not sure the speeds and loads will be there for all out race linings. Besides the temperature range, how the linings feel to him - the release and grabbyiness - will be important to how comfortable and confident he feels with them.
Save and measure the original leafs. Important reference point and those may end up being better than a repop.
On track, definately increase that front roll resistance. If there had to be a choice, do that over the leafs. Use polyurethane end link bushings with heavier washers and sleeve.
</quote>
The good ones will be $$. With close to stock springs, the ones he has should be serve.
[quote]
Does the car have the optional shoulder belt? That's not a quick and easy if not installed but would be good start.
Scroth claims to have a safe, DOT approved, 4 point harness. I've never felt fully confident in that claim, especially as a retrofit into one of our cars. But they've had it out for over 15 years so could be worth writing them.
My concerns are (a) riding up off the hips while driving. (b) no cross strap for the shoulder belts during a crash situation.
I think so.
A cheap freebee is to drop the nose a little and align for a little more agressive camber and caster. Use shoe polish if you don't have a pyrometer or time to use it at the track. The best specs will be dependent on the tire, and to some degree the car and driver.
Keep an occassional eye on the oil pressure. If it seems to keep dropping (relative to rpm) after water temperature has stabalized it may be getting hot enough during the sessions that a heavier grade will be needed to maintain viscosity. or it just may be oil return and pan control.
#2605546 - 01/12/19 04:41 PM Re: Starting w stock '68 RoadRunner - First steps? what shocks? [Re: 67SATisfaction]
BigBlockMopar Offline
Loc: The Netherlands
1. Tires.
Forget those Coopers. They are a cheap tire with matching cheap performance.
With a good 'brand' tire like Goodyears/Michelin, traction will be improved greatly.
I've heard about improved drumbrake linings but this will mostly put more heat into the already inadequate drums.
I would at least look into fabbing ducting to direct/route fresh air onto each wheel/brake.
Brake-fade might put a quick end to the fun after just a couple of rounds.
Bilstein, QA1, Hotchkis/Fox all make good shocks which will be a league above the 'cheaper' stuff out there.
Adjustable shocks would preferred. This will also greatly improve regular driving and are easy to install.
How about securely fabbing/mounting a temporary sheet of rubber to improve grip on the seat.
BigBlockMopar.com
#2605595 - 01/12/19 06:54 PM Re: Starting w stock '68 RoadRunner - First steps? what shocks? [Re: 67SATisfaction]
MarkM Online   content
Worthy
Loc: USA, MI
I wouldn't piecemeal it since everything really needs to be setup together. I would call Hotchkiss and inquire about one of there complete kits and then call Doctor Diff for brakes.
If you absolutely have to do it in pices then brakes first, rims and tires and next sway bars.
'87 Fifth Avenue: 512 low deck roller / 518 / 8.75
#2605629 - 01/12/19 08:08 PM Re: Starting w stock '68 RoadRunner - First steps? what shocks? [Re: 67SATisfaction]
CKessel Online   content
Loc: Los Osos, Ca
And buy Andy F's book on updating the b-body suspensions. Lots of great info in there.
Carl Kessel
#2605702 - 01/12/19 10:10 PM Re: Starting w stock '68 RoadRunner - First steps? what shocks? [Re: CKessel]
AndyF Offline
Loc: Oregon
That is what I was thinking. Why would I type a reply when I already typed a whole book?
#2605720 - 01/12/19 11:12 PM Re: Starting w stock '68 RoadRunner - First steps? what shocks? [Re: 67SATisfaction]
Loc: Albany, NY
Thanks guys, for the well crafted advice, including Skeptic who lived up to his name thumbs but still offered advice. I tried my best to write a "bump" comment that showed I took encouragement, and not offense at not having gotten any comments yet.
Thanks for the time you put into your advice. Our goal is to read it and select some or all of the incremental upgrades without "losing control" of the many variables of the RR's dynamics.
I know my own car well enough from tracking it for 4 years , gradually improving it, and I've learned the lesson that can come from making modifications without enough consideration, without documenting the baseline, or without thinking of the 'whole package'. Then you have to undo what you did to understand what went wrong. Been there done that. Trying to avoid it for my brother's RR.
Skeptic, "There isn't a single point that indicates an effort to make the car even marginally safe on a track.".. may I suggest you are over-thinking this.? This is an entry level amateur driver effort looking for incremental improvement.. read on for more explanation..
Last year my brother was an amateur driver, out for his first track day ever, with the motorsports club I belong to. They are a group of track racing enthusiasts who welcomed him and his RR.
.. Our type of club racing takes place at road courses all over our area every season. Our club rents the track and the staff. Club members are the drivers who pay a fee that covers the track rental cost. Drivers bring whatever car they have, have it pass tech inspection, and see what it'll do. We race against the clock, not "door-to-door". Drivers are given a thorough orientation. New drivers are coached. Car/driver combinations are assigned Groups according to performance and ability. Groups go out in Sessions. Cars are cleared onto the track by the Stewards at timed intervals to reduce "traffic jams". At our track, the track stewards can be relied on to perform diligent tech inspections, watch the drivers and cars carefully during track sessions, and flag drivers or cars they observe are behaving too hazardously. Rules are enforced. Violators are ejected from the track day.
This is how safety is handled so that any car that passes tech can participate, and drivers are kept in check. For a newbie driver and car combo, this gets them a controlled, coached environment in which to establish their baseline, and gets them feedback. Tech inspection found nothing to keep my brother or the '68 RR off the track, and as competitive as I am with my brother, I'm actually proud to say he got praised by the stewards and club organizers for how well he handled the beastly RR.
I wonder how this compares to the way your club or race track handles safety with cars and drivers of greatly varying or even unknown performance sharing the same track.
Best,
- Art
Edited by 67SATisfaction (01/12/19 11:17 PM)
#2605771 - 01/13/19 06:20 AM Re: Starting w stock '68 RoadRunner - First steps? what shocks? [Re: 67SATisfaction]
Dilbert Offline
Loc: out riding & passing you
Skeptic needs to go back to the straight line race forum. I love advice from people who have never cooked their brakes on a road course.
Lot's of regular cars pass tech and do laps.
OP I have years of road course time and obviously so does Matt!
Great advice by Mattax who has cooked several sets of brakes
Seat belts are a deal breaker. Put a real set belt [race belt]in for the lap belt. A real seat would be extremely beneficial
High performance brake shoes are required
DOT4 NOT 5 fluid
Rochester Clutch and Brake for the shoes
585-924-3717
Tires tires tires be square with the sizes - same size.
If you have $$$$ try 16's 255-50-16 works well in just about everything and there are great tires n that size.
Shocks are critical
Seat belts
Tires
I would not worry about cooking the brakes as a novice.
Wheels with cooling slots will be beneficial
#2605925 - 01/13/19 12:47 PM Re: Starting w stock '68 RoadRunner - First steps? what shocks? [Re: 67SATisfaction]
topside Offline
Loc: So Near, Yet So Far
A '70 Satellite wagon I had was really transformed with up-sizing the front swaybar and adding a rear one.
The thing about brakes, besides fade, is that the better you buy, the deeper you can carry speed into a turn; also, braided lines help with feel.
As much wheel & tire as you can get in there, and given the car, yeah a "square" dimensional setup is most likely best. Power & gearing play into that a bit, and understeer/oversteer preference too. As far as Coopers, their Zeon RS dry tires have been great on my Mustang, and tires will be a consumable item on a RR.
I'd be inclined to put a proper oil pan on it for improved pickup & added capacity.
Stiffening the structure will make the car more predictable and separate flex from suspension response. Makes changes & tuning less confusing.
The seat & belt deal means at least 4 or 5 point, then bolstering, so the stock appearance thing is gonna suffer. Midpoint in that would be OEM-looking buckets with added bolstering, like what's available for early Camaros but not to my knowledge for Mopars, meaning a talk with a good upholsterer.
#2606895 - Yesterday at 10:24 AM Re: Starting w stock '68 RoadRunner - First steps? what shocks? [Re: AndyF]
Loc: Albany, NY
What can be better than a spontaneous, unsolicited recommendation? Thanks!
I've ordered two copies - one for each of us - didn't know it was authored by our very own AndyF - do we Moparts folks get a specially autographed version? wink
(I looked at it on Andy's website some time ago, but I misunderstood the emphasis was on building a stroker.. with brake options, then weight savings, steering box, and some suspension advice thrown in afterwards.)
Cheers,
- Art
#2606949 - Yesterday at 11:53 AM Re: Starting w stock '68 RoadRunner - First steps? what shocks? [Re: 67SATisfaction]
Loc: Albany, NY
Thank you all again. Quick summary to date:
1. Tires/Rims.
Yes, since he plans keeping the 14" OEM Magnums for street use. The new rims/tires could be dedicated to track use. I'll ask him if that's his thinking. If so, look at 16-17-18", with an eye on whatever disc conversion he is thinking about in future. 255-50-16 are pricey, how about 225-50-16's? I'll ask him to scrutinize his Cooper choice just so he's sure on his decision (maybe the Zeon RS in 225-50-16 for $102/ea?). Tire size: Square. Select rims with good ventilation.
2. Brakes.
Flush DOT 3 out and upgrade to DOT 4. Valvoline synthetic. I have a laser to measure brake temperatures (we also use the laser to adjust tire pressure by measuring temperature spread). He did get brake fade last year. Source upgraded shoe linings from Rochester. Look into steel braided lines and ducting cool air.
3 Suspension.
Front sway from Hotchkis, w polyurethane bushes and HD seats and sleeves. Plan is to leave the OEM rear leafs as is. No rear sway. But we'll 'review w Hotchkis and be clear our goal is a bit more oversteer. Discuss shock recommendations w Hotchkis.
- Alignment? I've never tweaked my Mopars but will search here, see what you guys are operating with. My track car is dropped 30mm front, 1.5 degrees added camber, 2 degrees total toe-in, and little caster. I'm really not tempted to mess with the RR's alignment much (I can't understand those offset cam bolts for our UCA's)... unless I can get two days scheduled w a shop. We'd need to get the new alignment, then road test and back to adjust it as needed. That's cutting it close to track time, and if alignment ain't good he's going to be hating it all day. ..although I'll see what I can find on YouTube to teach me.
4. Shocks.
I'll talk with Hotchkis, see what they recommend to go with their front sway, and whatever we decide for the rear - just the stock rear leafs or add a mild sway.
5. Seats & belts.
His RR has the factory option 3-point harness. He didn't complain last year, but I'm trying to anticipate with more grip he'll stay comfortable. I'll ask him what he thinks. Possible Scrotch harness. Thanks for the idea of the rubber seat pad, we have those wicked grippy pads under some furniture cushions - that should work really well. The other drivers will love this.!
Other:
- Should've mentioned that we are not blinded by improving just the car. Developing driving skill ranks topmost in improving lap times. So, coaching will happen before and during track day.
- Monitor oil pressure. Possible new oil pan for proper pick up.
- Monitor body flex.
Looking down the road I'm not sure where he'll want to draw the line between OEM appearance and racing it. I know the more you make it track car, the less it is useful as a street car. Neither of us have truck & trailer, so driving to and from track limits us to mods that are street legal. Just one of those things.
Cheers,
- Art
#2607325 - Yesterday at 11:43 PM Re: Starting w stock '68 RoadRunner - First steps? what shocks? [Re: 67SATisfaction]
topside Offline
If "our goal is to increase oversteer" (in other words, less understeer) = add a rear bar.
I generally run as much caster as I can (most ever has been +7.2), which improves bite, feel, and tracking. Seems universal so far (Mopars, Camaros, Mustang).
Dual-purpose road course & street in mild to medium efforts has always given me a better street car. Different from dual-purpose drag cars I've had.
For a separate track tire & wheel, not only ventilation but lighter weight will help: less rotational mass & unsprung weight.
25,688 Registered Members
196,636 Topics
Correct Front Wheel Cylinders for 10" Drum on an A-Body?
by vinnyd76
26 minutes 39 seconds ago
Long rams
by 67R/T4speeder
36 minutes 8 seconds ago
Bye Tappen Zee bridge
by bigdad
Today at 08:33 AM
Anyone have their 8 track tapes reburbished?
by Charger446
Today at 08:30 AM
