#2604246 - 01/09/19 10:44 PM What am I doing wrong? T/A spoiler install
BDW Offline
Loc: Florida
70 Challenger
I have the First Place Auto repo T/A rear spoiler.
It has the floating mounting plates, and they don't seat and just want to twist and pull out before I can get the mounting nut tight.
Is there a trick to this I'm missing?
Thx
#2604733 - 01/10/19 09:28 PM Re: What am I doing wrong? T/A spoiler install [Re: BDW]
EL5 71 Offline
Loc: New York, USA
When you install the brackets inside the spoiler, you lock them in place with the push retainers right? Those usually hold the brackets steady while you tighten.
#2605120 - 01/11/19 06:12 PM Re: What am I doing wrong? T/A spoiler install [Re: BDW]
BDW Offline
Loc: Florida
Yeah, I have the screw on retainers snug. The problem seems to be the bracket and underside of the spoiler are so smooth, they easily spin with the slightest torque.
To compound the problem, the molded indents are so small, they do nothing to hold the bracket straight.
#2605250 - 01/11/19 10:22 PM Re: What am I doing wrong? T/A spoiler install [Re: BDW]
Aar1064 Online   content
Loc: Ashland City, Tennessee
With that bracket spinning as you say I can see your pain. Can’t do anything about the indents but if the bracket is bent similar to a “V” then the ends wouldn’t grab like they need too. If they are ok I’d try screwing on two 1/4 inch nuts behind the spoiler nut used to retain spoiler. Leave them close to the end and tighten them so they’re tight against one another and use these as a way to hold bracket in place as you tighten the spoiler nut.
Hopefully there’s enough room to tighten with a wrench.
25,688 Registered Members
196,636 Topics
Correct Front Wheel Cylinders for 10" Drum on an A-Body?
by vinnyd76
26 minutes 39 seconds ago
Long rams
by 67R/T4speeder
36 minutes 8 seconds ago
Bye Tappen Zee bridge
by bigdad
Today at 08:33 AM
Anyone have their 8 track tapes reburbished?
by Charger446
Today at 08:30 AM
