Factory 4-bolt Chrome BB Valve Covers #2605197
01/11/19 11:35 PM
01/11/19 11:35 PM
Danville, NH
Mopar_Mike Offline OP
Danville, NH
Did Chrysler make factory 4-bolt hole chrome valve covers for big blocks? Thanks.
RS23L7 4-Speed
Re: Factory 4-bolt Chrome BB Valve Covers [Re: Mopar_Mike] #2605200
01/11/19 11:40 PM
01/11/19 11:40 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Yes, I have a pair, unsure if they were parts dept or come on a vehicle.
Re: Factory 4-bolt Chrome BB Valve Covers [Re: Mopar_Mike] #2605203
01/11/19 11:41 PM
01/11/19 11:41 PM
Danville, NH
Danville, NH
Thanks, I thought maybe the 426 Street Wedge was 63-64-65, but I believe it is only 64-65.. in which case it be 5-bolt
RS23L7 4-Speed
Re: Factory 4-bolt Chrome BB Valve Covers [Re: Mopar_Mike] #2605284
01/12/19 03:59 AM
01/12/19 03:59 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Don't we have 4 bolt and 6 bolt?
Re: Factory 4-bolt Chrome BB Valve Covers [Re: Mopar_Mike] #2605285
01/12/19 04:03 AM
01/12/19 04:03 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I've seen exactly one set that I was sure were factory and they were on a pilot car engine. It was a 413 mocked up to look like a 64 426 Street Wedge in a 64 Fury pilot car.
Re: Factory 4-bolt Chrome BB Valve Covers [Re: Mopar_Mike] #2605299
01/12/19 06:04 AM
01/12/19 06:04 AM
1962 and 1963 M.W heads had 4 bolt valve covers but my 1963 415 HP and several other 4 bolt valve covers I've seen had the extra material around the lower end corners like the 1964 and later valve covers had but no holes in them shruggy work
None of the OEM M.W. valve covers had wire looms on the passenger sides due to no room between the valve covers and the intake manifold, the baffles in them where higher also to clear the adjustable ductile iron rocker amrs scope
The first set of stock chrome valve covers I saw was on a 1965 426 street wedge motor shruggy
Re: Factory 4-bolt Chrome BB Valve Covers [Re: NANKET] #2605307
01/12/19 08:05 AM
01/12/19 08:05 AM
Danville, NH
Danville, NH
Yes, lol, 4 and 6.. not sure why I said 5..
The set I have do not have wire looms on them or the extra corner material like Cab said. I wonder if someone just had a set of MW chromed, or two 4-bolt LH ones chromed?? They definitely are original covers one way or another..
RS23L7 4-Speed
Re: Factory 4-bolt Chrome BB Valve Covers [Re: Mopar_Mike] #2606263
01/14/19 01:25 AM
01/14/19 01:25 AM
Likely cuz small blocks only have 5 (I got your back!).
