Factory 4-bolt Chrome BB Valve Covers
#2605197
01/11/19 11:35 PM
01/11/19 11:35 PM
Posts: 4,280 Danville, NH
Mopar_Mike
Danville, NH
Did Chrysler make factory 4-bolt hole chrome valve covers for big blocks? Thanks.
RS23L7 4-Speed
Re: Factory 4-bolt Chrome BB Valve Covers
[Re: Mopar_Mike]
#2605203
01/11/19 11:41 PM
01/11/19 11:41 PM
Mopar_Mike
Danville, NH
Thanks, I thought maybe the 426 Street Wedge was 63-64-65, but I believe it is only 64-65.. in which case it be 5-bolt
RS23L7 4-Speed
[Re: Mopar_Mike]
#2605299
01/12/19 06:04 AM
01/12/19 06:04 AM
Posts: 43,090 Bend,OR USA
Cab_Burge
1962 and 1963 M.W heads had 4 bolt valve covers but my 1963 415 HP and several other 4 bolt valve covers I've seen had the extra material around the lower end corners like the 1964 and later valve covers had but no holes in them None of the OEM M.W. valve covers had wire looms on the passenger sides due to no room between the valve covers and the intake manifold, the baffles in them where higher also to clear the adjustable ductile iron rocker amrs The first set of stock chrome valve covers I saw was on a 1965 426 street wedge motor
[Re: NANKET]
#2605307
01/12/19 08:05 AM
01/12/19 08:05 AM
Mopar_Mike
Danville, NH
Yes, lol, 4 and 6.. not sure why I said 5..
The set I have do not have wire looms on them or the extra corner material like Cab said. I wonder if someone just had a set of MW chromed, or two 4-bolt LH ones chromed?? They definitely are original covers one way or another..
RS23L7 4-Speed
[Re: Mopar_Mike]
#2606263
01/14/19 01:25 AM
01/14/19 01:25 AM
RapidRobert
Yes, lol, 4 and 6.. not sure why I said 5.. Likely cuz small blocks only have 5 (I got your back!).
