48° small block cam Number decoding help #2604995
01/11/19 04:04 PM
01/11/19 04:04 PM
CA.
RAY1969CARS Offline OP
CA.
Re: 48° small block cam Number decoding help [Re: RAY1969CARS] #2605001
01/11/19 04:24 PM
01/11/19 04:24 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
IIRC from the Reed cams I had, 300 and 310 are the duration, 5A2 means it is ground on 105 with 2* advance.
This guy used to work for Reed and might could help if no one has an old Reed catalog-
http://www.demoscams.com/
Thinking back, my last 340 cam from Reed was 300-310. Can't remember the lift but it was wicked with the 3.91 gears and a 4 gear. up
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: 48° small block cam Number decoding help [Re: I_bleed_MOPAR] #2605009
01/11/19 04:54 PM
01/11/19 04:54 PM
CA.
CA.
Thank you
