#2599395 - 12/31/18 05:18 PM Mopar Transmission Wanted - 1st Quarter
moparts Offline
#2599573 - 12/31/18 09:36 PM E-Body 4 speed Transmission Wanted [Re: moparts]
BS27R1B Offline
Loc: Strathroy, Ontario
Looking to buy an 18 spline E-Body transmission, bell housing and pistol grip shifter.
Found a transmission but still need bell housing and complete shifter setup.
Rick Simpson
Please PM or email me at topshelfcars at hotmail.com
Thanks for the free ad Tom!
Edited by BS27R1B (01/09/19 10:58 PM)
'.. it was long ago and it was far away, and it was so much better than it is today..'
Jim Steinman
#2599695 - 01/01/19 07:38 AM Re: Mopar Transmission Wanted - 1st Quarter [Re: moparts]
6PAX Offline
Loc: Metro Detroit
Wanted; Big block 727 transmission with part of #3515848, 3410670 or 3410672. Prefer if in the Detroit area for pickup so as to avoid having to ship.
Complete factory automatic kickdown linkage set-up for a 67-69 big block A-body.
gt340 @ yahoo.com
#2601054 - 01/03/19 03:30 PM Re: Mopar Transmission Wanted - 1st Quarter [Re: moparts]
Doc Fiberglass Offline
New title coming soon...
Loc: ...to Paradise from ParaICE !
727 aftermarket shorty tail shaft kit .., 62-5 or 66-71 ok too ... Complete kit or parts are ok too ...
...... from being a Fine FlapperGlas Fabricator to now a full time beach bum and part-time dirt-farmer - tending a small up-north Meeeeechigan purchased aPpLe orchard !
#2601055 - 01/03/19 03:33 PM Re: Mopar Transmission Wanted - 1st Quarter [Re: moparts]
Looking for Plymouth or Chrysler push button shifter assemblies..... AND ANY OTHER vertical positioned buttons(Dart ?) whatchoogot?
#2603911 - 01/09/19 11:39 AM Re: Mopar Transmission Wanted - 1st Quarter [Re: moparts]
gzig5 Offline
Loc: Mequon, WI
Wanted... Four speed conversion stuff
Shifter mount plate for A833 in an E-body application.
Pistol grip shifter handle for E-body. Doesn't need to be perfect, missing or broken grip plates considered.
E-body clutch/brake pedal assembly
E-body Z-bar and attendant parts.
E-body trans tunnel
Essentially, I have the A833 trans, shifter, rods, clutch, throwout, bellhousing and fork, flexplate. I need everything else. Would consider hydraulic clutch actuation if it is street oriented. PM if you have something.
Edited by gzig5 (01/09/19 11:40 AM)
#2603922 - 01/09/19 12:09 PM Wanted: SB 727 Trans Dust Shield Two-Piece [Re: moparts]
vinnyd76 Online   content
Loc: Macomb, MI
I'm looking for a small block 727 trans dust shield that is a two-piece with an access to drain torque converter fluid.
#2604425 - 01/10/19 11:39 AM Re: WANTED : Used 8 bolt Flex Plate for RB [Re: moparts]
moparx Online   content
Dreaming of implants
Loc: north of coder
Wanted : used, RB 8 Bolt Flex Plate for 10" bolt pattern, 7/16" bolt size converter. expired SFI cert preferred.
PM me here, or : moparx "at" windstream "dot" net.
Thank You for the add MOPARTS ! up
beer
THANK YOU MOPARTS ! FOUND ONE !
beer
Edited by moparx (01/12/19 10:53 AM)
#2606752 - 01/14/19 10:36 PM Re: WANTED : Used 8 bolt Flex Plate for RB [Re: moparts]
wish4hemi Offline
Loc: IL
Looking for an 8HP70 8 speed transmission. Applications below. Prefer 2WD version, but 4WD could be made to work. Looking for something in the Illinois/Indiana/Missouri/Kentucky/Tennessee area. I'm near zip 62428. Send me a PM here.
2015-2019 Chrysler 300 with 5.7 Hemi
2015-2019 Dodge Challenger with 5.7 or 6.4 Hemi
2015-2019 Dodge Charger with 5.7 or 6.4 Hemi
2013-2019 Ram 1500 with 5.7 Hemi
2014-2019 Jeep 5.7 or 6.4 Hemi
25,688 Registered Members
196,640 Topics
Correct front wheel cylinders for 10" drum brake A-Body?
by vinnyd76
01/16/19 11:22 AM
Holley Debuts G3 Hemi Valve Covers From Sniper EFI
by Rustymuscle
01/16/19 11:20 AM
Sweptline parts trucks 2 1/4 ) Lincoln , Neb $2500
by bigdad
01/16/19 11:14 AM
1964 Plymouth 4 door , Lincoln Neb area --$800
by bigdad
01/16/19 11:09 AM
