Re: Replace dash amp meter with a volt meter? [Re: MO_PA] #2605560
01/12/19 07:58 PM
01/12/19 07:58 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
To debate that anything never caused an issue in any vehicle is the true folly.
Everything needs occasional servicing. The factory didn't care about 50+ year life spans so you are on your own to keep up with this kind of stuff.
Pretty obvious your level of comfort with electricity is very low.
Don't be the exception.
Re: Replace dash amp meter with a volt meter? [Re: MO_PA] #2605561
01/12/19 08:01 PM
01/12/19 08:01 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
not on mine... while the alternator on car is the correct output, something that factory never did, the ammeter won't get ( or barelly get ) any load reading wink. that was the real problem for them... but... I have discussed and proved this many times allong with @mattax, @71deputy and some other
just those what doesn't understand how the system work, will deny everything wink
Re: Replace dash amp meter with a volt meter? "UP DATE" [Re: DAYCLONA] #2605896
01/13/19 02:47 PM
01/13/19 02:47 PM
moparx Offline
moparx  Offline
dayclona, would that last pic you show for $44 from advance possibly be small enough to be fitted into my 69 charger ralley dash and look close enough in font to the rest of the dash gauges ?
beer
