Re: two step
[Re: moparsquid]
#2604193
01/10/19 12:06 AM
01/10/19 12:06 AM
Posts: 20,165 Park Forest, IL
slantzilla
Park Forest, IL
I have hooked them up to the brake light switch, a pressure switch in the brake line or the trans brake switch. All depends on what you want to accomplish.
Re: two step
[Re: moparsquid]
#2604778
01/11/19 03:12 AM
01/11/19 03:12 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Just as slant said above, it depends on the surrounding hardware. If it’s a footbrake car, the best option is to install a pressure actuated switch into the brake system and run it off that. The easiest is to wire it right into the brake light switch. This is how my car is done and it has worked great and reliably for me for years now.
Re: two step
[Re: slantzilla]
#2604837
01/11/19 12:02 PM
01/11/19 12:02 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I have hooked them up to the brake light switch, a pressure switch in the brake line or the trans brake switch. All depends on what you want to accomplish. Many a Ford has caught fire when a brake pressure switch started leaking. Seen it happen to a friends F150 after it had been parked for 3 hours. Lucky for him I was having a smoke and saw the start of it, I grabbed a fire extinguisher and put it out. He left his doors unlocked. I would forgo a two step rev limiter before I used a brake pressure switch, especially since you already have a switch on the pedal.
Re: two step
[Re: moparsquid]
#2605012
01/11/19 04:55 PM
01/11/19 04:55 PM
Posts: 954 Chicago
PurpleBeeper
Chicago
I REALLY like slantzilla's idea of wiring into the brake light switch.
If you have a 4-speed car, then maybe a push button the shifter? I have a 2-step which isn't installed yet and plan to wire it together with a line lock to a switch on the shifter (since I need both feet to launch & I have 3 pedals)
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
Re: two step
[Re: PurpleBeeper]
#2605029
01/11/19 05:40 PM
01/11/19 05:40 PM
Posts: 4,457 Washington
madscientist
Washington
If you have a 4-speed car, then maybe a push button the shifter? I have a 2-step which isn't installed yet and plan to wire it together with a line lock to a switch on the shifter (since I need both feet to launch & I have 3 pedals) If you have a clutch the switch goes on the clutch pedal, not on the line lock. I don't care how good you are, you will never get the button off at the correct time twice in a row. Set it up on the pedal and make sure that as soon as you move your foot the switch clicks. That way, your not loading the engine while the two step is on. That's a promised parts breaker.
Re: two step
[Re: madscientist]
#2605184
01/11/19 11:18 PM
01/11/19 11:18 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
I have two switches in series,one mounted to my clutch pedal stop on the floor and the other on the transmission at the first gear lever. That way the 2 step circuit is only active when the clutch pedal is on the floor and the tranny is in first gear. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
