68 vin vs body I D numbers
#2602003
01/05/19 06:33 PM
01/05/19 06:33 PM
Posts: 1,608 fresno ca
mikeysmopars
fresno ca
Question for the guru's regarding 68 vin numbers and rear trunk lip numbers. I'm building a 68 Coronet for my kid and was curious how anyone can tell from the VIN weather how body ID number matches the rear trunk lip, I know 69 n up the vin matches that numbers but 68 and back doesn't?
Founder and CEO of the Central Valley Mopar Drag Pack
Re: 68 vin vs body I D numbers
[Re: Alaskan_TA]
#2602257
01/06/19 12:07 AM
01/06/19 12:07 AM
Posts: 43,511 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
If you can tell the fender tag has never been off then that is all you need. Paperwork always helps...
JB Rhinehart, Realist
A-Body's RULE!
[Re: mikeysmopars]
#2602480
01/06/19 04:37 PM
01/06/19 04:37 PM
Posts: 3,392 cheshire, ct
davesmopars
cheshire, ct
Vin tag, fender tag and body numbers ties the car together, Certicard would also help. I believe 68 and older cars, the fender tag is more important than the vin tag but of coarse you need the vin tag.
Build sheet!!!
Keeper of the 440 M code Cuda registry mcodecuda@yahoo.com
[Re: mikeysmopars]
#2602918
01/07/19 02:21 PM
01/07/19 02:21 PM
mikeysmopars
fresno ca
I don't have the fender tag or build sheet🙄. It's just a 318 auto car but was curious on the 68 and back cars why the body numbers weren even close to the VIN. Thanks for the help, if the fender tag surfaces I'll chime back in.
[Re: mikeysmopars]
#2603991
01/09/19 05:20 PM
01/09/19 05:20 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
I don't have the fender tag or build sheet🙄. It's just a 318 auto car but was curious on the 68 and back cars why the body numbers weren even close to the VIN. Thanks for the help, if the fender tag surfaces I'll chime back in. Your body is stamped E - Los Angeles 8 - 1968 W - Coronet 094485 - Order Number The order number is on the fender tag, build sheet and Window Sticker also. The build sheet and Window Sticker are the only thing that ties to the two numbers together.
